Hello guys!
Relatively new to the site but I just wanted to share my S4 build! First of all I would like to thank Josh from NFC for answering all of my questions and for getting my S4 shipped out quickly! Josh truly made an excellent SFF case! I have no complaints with the build quality and everything fit perfectly!
Now on to the build! Specs are listed below...
This build was built around the Xbox One Power Brick that I had lying around from a dead Xbox One.
I prefer this brick over others because it is purposely designed to remain on for extended periods of time (Xbox One standby mode), it is decently quiet, and provides the most power I can find for a 12V power brick of its size. Distributing the power is of course a MiniBox Pico 160XT PSU that as been modified with 18 gauge sleeved wiring and 14 gauge power in wiring. In order to adapt the Pico to the xbox brick I cut the power connecter away from the dead xbox one motherboard and wired up 4 18 gauge wire leads in as seen below. These leads then terminate into 14 gauge wiring all the way up to the pico. This should be more then enough to handle the expected wattage of the system.
Speaking of system wattage... I did some testing while I had all of my parts out of the S4 case to see just how much power the system was drawing during various use cases. The results of my testing are listed below.
Idle: 40-50 watts
Typical usage (Internet, Office, etc): 55-60 watts
100% CPU load: 90-100 watts
100% GPU load 30% CPU (typical gaming load): 150 watts with peaks around 170 watts
Full Load 100% CPU 100% GPU: 205 watts with peaks as high as 230 watts
As you can see I am well within the Xbox One power brick rating for most of the usage cases. At artificial full system load my power does peak around 230 watts but I saw no stability issues and the Xbox One brick handled it without issue.
Because of the size of the xbox one power connector this required a bit of modification to the S4 Mini's power connector mounting. I basically started by cutting away a rectangle area starting from the cutout for the video card mount to almost the outer diameter of the stock hole as seen in the pic below. From here I removed the 5mm Aluminum trim and drilled two holes in the GPU vent panel as mounting points. Using custom plastic standoffs I then screwed in the xbox one power connector and achieved this result
As you can see, everything that I could sleeve is sleeved.
After these modifications to the S4 the rest of the install was pretty straight forward. I ended up using a different riser card as NFC's riser cards are out of stock. I purchased an "ezdiy" 10cm riser from amazon and it works pretty well! I lost some but not much performance from the 960 but I believe that has to do with the bends required to fit this riser card in. Below are the final build pictures! I still have some work to do with the SATA cable routing but for now they will remain. Let me know what you guys think!
- Gigabyte GA-Z170N-WIFI
- Intel Core i5 6500
- Noctua NH-L9i Cooler
- 16gb DDR4 2133mhz Kingston HyperX Fury memory
- 2 120gb SSD's (mixture of 840 pro and intel SSDs as I had those lying around)
- 1 1TB USB 3 external HDD for steam library
- EVGA GTX960 SC Mini ITX
- Pico 160XT PSU Customized (more on that below)
- Xbox One 215 watt power brick
Idle: 40-50 watts
