Thank you again for sharing, much appreciated!
It's a bit sad still - I guess the 2 rad setups in this case really need all the space in front/behind the rad/fans they can get to actually perform well.
Just as an estimate, how many watts are the CPU & GPU using on average when you're running these tests?
Also in the second and third test runs, did you remove the side radiator completely, or just remove the fans? Or did you leave both in and simply disabled the fans?
I would be happy if I will achieve similar results as in that run for my single rad, 3xNF-A12x15 setup, as long as I can guarantee good airflow
