Log FormD-T1 case by x111
x111
114
45
old version:
Configuration:
- AMD Ryzen 9 3900X
- ASUS ROG STRIX X570-I GAMING
- PowerColor Red Dragon Radeon Rx 5700 Xt
- Samsung 970 PRO 512GB NVMe M.2 SSD
- Sabrent 2TB Rocket Nvme PCIe 4.0 M.2 SSD
- CORSAIR Vengeance LPX 64GB (2 x 32GB) DDR4 3200 (PC4-25600) C16
- Corsair SF750
- Riser 3M 8KC3-0726-0300
- Alphacool Eisdecke DDC brass top
- EK-DDC 3.2 PWM pump
- Noctua NF-F12 iPPC 3000 PWM
- Noctua NF-P12 redux-1700 PWM (2)
- Noctua NF-A9x14 PWM 2.52W
- Women Stocking XXL (pantyhose) as a filter.
Took me some time to remove that nasty paint from DDC brass top.
I put extra red automotive silicon between pump and brass top, to make sure 100% no water will go out
This build took way too much time. It is also my first full custom water loop.
I am going to make some changes soon when I will get different radiator.
Also, I am aware that those tubed look nasty and full of air, not much but not clean properly. I will replace them soon. This is only test run for now.
It would great to finally get nvidia 3080 and AMD Ryzen 9 5950X
Hope soon it will be available for purchasing.
quick update:
P.S. I will edit if I forgot something.
Reactions: tinyitx
tinyitx
2,112
2,082
4 questions:-
a. what are the thermals of the two M.2 SSDs?
b. do you wash and re-use the panty hose when it gets dusty, or do you just throw it away and put on a new one? How often do you do this? (Edit: just remember this is a new system and so you probably do not know this in a while)
c. With and without the panty hose, how does the thermal differ for the CPU and GPU?
d. what do those few pieces of black electrical tape fix?
x111
114
45
4 questions:-
4.a
solid under 40C
4.b
simply vacuum and get new ones when its get old.
and by far is the best filter I had used, thanks to ladies.
You do not need to replace it often if vacuum often.
in my last build
I used that filter for over 6 mounts.
4c.
without filter temps are better for sure but I did not even measured correctly, I will never use my pc without a filter.
4.d
those few piece of electrical tape holding my second SSD which has zero room on the back.
drdaz
I know this is an old thread, but what water block did you use on the GPU here? I've also got the Red Dragon in the T1, and I've been using the stock cooler because all the blocks I looked at seemed to be a millimeter or 3 too tall.
Would love to be able to get the whole thing on liquid.
EDIT: That's alphacool's block I think...
