"Info taken from TitanRig email flyer noting availability"
Route Tubing Behind Your Motherboard With Bitspower's New Summit Revo CPU Waterblocks
Bitspower revolutionary CPU water block design - which also excels in meeting the challenges posed by new-generation CPUs presents Summit Revo, a cutting-edge water block that combines new concepts with innovative design. Not only does its appearance evoke a refreshing feeling, but its thermal performance also excels in meeting the challenges posed by new-generation CPUs.Examining the front of the Bitspower CPU Block Summit Revo reveals a deliberate absence of outlet holes on its main body. This design choice ingeniously leverages the motherboard's structure to direct water flow to the rear, where multiple strategically positioned outlet holes enhance user convenience. Such innovation guarantees an uncluttered top surface for the water block. If your preference leans towards a clean visual aesthetic, this cooling solution stands out as the optimal choice. Conversely, if you seek greater design customization, this water block affords you ample creative freedom.
Features:
• Available for Intel LGA1700 and AMD AM5 sockets
• Nickel-plated copper cold plate with high-density heat sink fins, and a water injection design
• A removable magnetic front bezel covers screw heads and features a dark tint for a stealthy appearance
• Six G1/4 ports on the backside provide multiple tube routing options
• DRGB lighting with standard 3-pin connection
• Intel version dimensions (L x W x H): 111.4 x 108 x 73.5 mm
• AMD version dimensions (L x W x H): 122 x 94.2 x 71 mm
