NCASE M1 V6 GPU Compatibility List
Necere
NCASE
3,284
This is not an exhaustive list, focused primarily on current gen top-tier cards (as these tend to be the largest). Downrange models often share designs with higher end models, so this should still be useful for determining compatibility with many of those cards. Note that until verified by users, compatibility is a best guess based on published specs and product photos, and will tend to be conservative.
Generally speaking, nvidia and AMD reference/Founder's Edition cards will always fit.
____________________________
GPU compatibility (M1 V6)
Graphics Card Support
Maximum length​
  • 322mm (cards up to 45mm (2.2 slots) thick)
  • 280mm (cards up to 60mm (3 slots) thick)
  • 300mm (cards up to 60mm (3 slots) thick with front I/O ports removed)
Maximum height (AKA width)​
  • 140mm at mid-card
  • 130mm (first 5mm at back corner)
  • 125mm (portion of card over 280mm long)
  • Please allow 15-20mm for PCIe power connectors
Bottom fan support​
  • 25mm thick fans: 2-slot (<42mm) cards only
  • 15mm thick fans: up to 2.5-slot (<50mm) cards
GPU support bracket​
  • 2 to 2.5 slot (<42mm-50mm) cards only
Note: The above dimensions represent the available space as simple rectangular prisms and are only an approximation. In reality, neither the available space nor graphics cards are perfect rectangular prisms. In particular, due to the angular designs of most GPU shrouds they rarely occupy the full length/thickness at the lower front. This approximation of the actual dimensions can sometimes mean that a GPU that does not fit on paper will fit in reality, which can only be determined through actual test fitment. The compatibility lists below are based on the listed dimensions so are only approximations, unless confirmed by a user.
The following diagrams provide a more detailed and accurate representation of the available space:
Detailed length/height diagram:
Please note this shows the maximum internal dimensions and does not account for card installation.
Example of a reference height card (PCB/cooler =~111mm tall) - no recessed connectors:
Example of a tall card (PCB and/or cooler over 111mm tall) - no recessed connectors; height added by PCIe power connectors can prevent installation in narrower cases:
Example of a tall card with recessed PCIe power connectors - reduced overall height may allow installation in more cases:
On waterblocks: GPU height is (usually) measured from the PCIe x16 edge connector to the top of the PCB or cooler shroud. Full cover waterblocks do not cover the PCIe edge connector, so the connector height (13mm) should be added to the waterblock height to determine the overall height for fitment purposes.
Generally speaking, only water blocks for cards with PCB height limited to the PCIe card specification (111mm tall) will fit in the M1.
Where low profile PCIe power adapters are indicated for fitment, ModDIY connectors are suggested.
AMD Card Compatibility List
ManufacturerModelLengthHeightThickness (slots)NotesCompatible?Fitment NotesFits with deshroud?
Multiple manufactacturersAMD Reference RX 6900/6800 XT267120~50YesMight need low profile PCIe power adapters
Multiple manufactacturersAMD Reference RX 680026712040YesMight need low profile PCIe power adapters
ASRockRX 6900 XT/6800 XT Phantom Gaming D 16G OC33014056No
ASRockRX 6800 XT Taichi X 16G OC33014056No
ASRockRX 6800 Phantom Gaming D 16G OC30513155No
ASRockRX 6800 Challenger Pro 16G OC30513155No
ASUSTUF GAMING RX 6800 XT/RX 6800310140.257.8No
ASUSROG STRIX RX 6800320128.757.3No
ASUSROG STRIX LC RX 6800 XT277130.843.6Attached AIONo
GigabyteAORUS RX 6800 XT/RX 6800 MASTERTBD
GigabyteRX 6800 XT GAMING OC28611858Yes
GigabyteRX 6800 GAMING OC28611258Yes
MSIRX 6800 XT/RX 6800 GAMING TRIO/X TRIO32414155No
PowerColorRed Devil 6800 XT/680032013562No
PowerColorRed Dragon 6800 XT/680031013554No
PowerColorFighter RX 680030012050Yes*
SapphireNitro+ RX 6800 XT/XT SE310134.355.3No
SapphireNitro+ RX 6800310.5134.255.2No
SapphirePulse RX 6800 XT313134.853.4No
SapphirePulse RX 6800303127.353.8Yes*
XFXSpeedster MERC 319 RX 6800 XT/RX 680034013854No
* Front I/O ports must be removed
§ Low profile PCIe power adapters must be used
† Installation may be difficult
Multiple manufacturersAMD Reference RX 5700/5700 XT27011142Yes
Multiple manufacturersAMD Reference Radeon VII26712040Yes
ASRockRX 5700 XT Challenger D 8G OC?12142Yes
ASRockRX 5700 XT Taichi X 8G OC+31113053Recessed power connectorsNo
ASRockRX 5700 Challenger D 8G OC?12142Yes
ASUSTUF Gaming X3 RX 5700 OC edition/RX 5700 XT OC edition26912554Yes
ASUSROG Strix RX 5700 OC edition/RX 5700 XT OC edition30513054Recessed power connectorsYes*†Confirmed
GigabyteRX 5700 GAMING OC 8G/RX 5700 XT GAMING OC 8G280114.349.6Yes
GigabyteAORUS RX 5700 XT 8G29012358Yes*†
MSIRX 5700 XT GAMING/GAMING X29714058No
MSIRX 5700 XT MECH OC23212646Recessed power connectorsYes
MSIRX 5700 XT EVOKE OC25412951Recessed power connectorsYes
MSIRX 5700 GAMING/GAMING X29714058No
MSIRX 5700 MECH OC23212646Recessed power connectorsYes
MSIRX 5700 EVOKE OC25412951Recessed power connectorsYes
PowerColorRed Devil RX 5700/RX 5700 XT30013253Yes*§†Confirmed
PowerColorRed Dragon RX 5700/RX 5700 XT24013241Yes§
PowerColorRX 5700/RX 5700 XT23011141Yes
SapphireNITRO+ RX 5700 XT 8G30613549Recessed power connectorsYesConfirmed; reverse sag
SapphirePulse RX 5700/RX 5700 XT25413546.5Recessed power connectorsYes
XFXRX 5700 XT RAW II27814058Recessed power connectorsYesConfirmed
XFXRX 5700 XT Triple Dissipation~315~13344Recessed power connectors
Possibly sold as THICC III Ultra
YesConfirmed
XFXRX 5700 XT THICC II/Pro/Ultra29313055Recessed power connectorsYes*†
XFXRX 5700 XT THICC III/Ultra31513157Recessed power connectors
Original 3-slot model per XFX website; retail model may have been replaced by the 2-slot Triple Dissipation design
No
Nvidia Card Compatibility List
NvidiaFounder's Edition RTX 30903131383-slotNo
NvidiaFounder's Edition RTX 30802851122-slotYesConfirmed
NvidiaFounder's Edition RTX 30702421122-slotYes
ASUSROG STRIX RTX 3090/3080/3070318.5140.157.8No
ASUSTUF RTX 3090/3080299.9126.951.7Yes§†ConfirmedYes
ASUSDUAL RTX 3070 8G26713552Yes§Confirmed
EVGAXC3285.37111.152.2-slotYesConfirmed
EVGARTX 3080 XC3 ULTRA HYBRID GAMING262.8112.12 slotAttached AIOYes
EVGAFTW3300136.752.75-slotYes*§†Confirmed
GainwardRTX 3090/3080 Phoenix/Phoenix GS2941122.7-slotYes*†
GalaxRTX 3090/3080 SG31711361No
GalaxRTX 3070 SG317113~2.5 slotYesConfirmed
GalaxRTX 3090/3080/3070 EX Gamer31612458No
GalaxRTX 3070 EX28512458Yes§
GigabyteAORUS RTX 3090/3080 XtremeNo
GigabyteAORUS RTX 3090/3080 Master31914070No
GigabyteRTX 3090/3080 Gaming OC32012955No
GigabyteRTX 3090/3080 Eagle OC32012856No
GigabyteRTX 3070 Eagle28211541YesConfirmed
GigabyteRTX 3090/3080 Vision32012655No
GigabyteRTX 3070 Vision28611551Yes
GigabyteRTX 3070 GAMING OC28611551Yes
GigabyteRTX 3090 TURBO26711140Yes
MSIRTX 3090 Gaming Trio/Gaming X Trio33514056No
MSIRTX 3080 Gaming Trio/Gaming X Trio32314056No
MSIRTX 3080 SUPRIM X33614061No
MSIRTX 3090/3080 Ventus 3X30512057Yes*†Confirmed
MSIRTX 3070 Ventus 3X30512152Yes*†Confirmed
MSIRTX 3070 Ventus 2X23212452Yes
PalitRTX 3090/3080/3070 GamingPro29411260Yes*†
PNYRTX 3090/3080/3070 XLR8 Gaming EPIC-X RGB Triple Fan29411259Yes*†
ZotacRTX 3080 AMP Holo317.8131.859.6Yes*Confirmed; reverse sag
ZotacRTX 3090 Trinity317.8120.758Yes*†Confirmed
ZotacRTX 3080 Trinity317.8120.758NoSee discussion starting here
Zotac3070 Twin Edge231.9141.341.5YesConfirmed, but certain combos may prevent installation
ASUSDual RTX 2080 Ti/OC edition26811458Yes
ASUSTurbo RTX 2080 Ti26911442Yes
ASUSROG Strix RTX 2080 Ti/Advanced edition/OC edition304.7130.454.1Recessed power connectorsYes
ASUSROG Matrix RTX 2080 Ti31013559.6Recessed power connectorsNo
ASUSDual RTX 2080 SUPER EVO/OC edition26711856Yes
ASUSROG Strix RTX 2080 SUPER/Advanced edition/OC edition299.7130.454.1Recessed power connectorsYes
ASUSDual RTX 2080/Advanced edition/OC edition26811458Yes
ASUSTurbo RTX 2080 Evo268111.340Yes
ASUSROG Strix RTX 2080/Advanced edition/OC edition299.7130.454.1Recessed power connectorsYesConfirmed
ASUSDual RTX 2070 SUPER EVO/Advanced edition/OC edition26711858Yes
ASUSTurbo RTX 2070 SUPER EVO268111.340Yes
ASUSROG Strix RTX 2070 SUPER/Advanced edition/OC edition299.7130.454.1Recessed power connectorsYes
ASUSROG Strix RTX 2070/Advanced edition/OC edition300.5130.648.9Recessed power connectorsYesConfirmed
EVGARTX 2080 Ti XC GAMING/BLACK EDITION GAMING27011140Yes
EVGARTX 2080 Ti XC ULTRA GAMING/XC2 ULTRA GAMING27011154Yes
EVGARTX 2080 Ti GAMING26511140Yes
EVGARTX 2080 Ti XC HYBRID GAMING26611440Attached 120mm AIOYes
EVGARTX 2080 Ti FTW3 GAMING/ULTRA GAMING30213954No
EVGARTX 2080 TI FTW3 ULTRA HYBRID GAMING29113940Attached 120mm AIONo
EVGARTX 2080 Ti FTW3 ULTRA HYDRO COPPER GAMING291158.540WaterblockNo
EVGARTX 2080 Ti K|NGP|N GAMING29113940Attached 240mm AIONo
EVGARTX 2080 SUPER XC GAMING27011140Yes
EVGARTX 2080 SUPER XC ULTRA GAMING/XC2 ULTRA GAMING27011154Yes
EVGARTX 2080 SUPER XC HYBRID GAMING26611440Attached 120mm AIOYes
EVGARTX 2080 SUPER GAMING/BLACK GAMING27011140Yes
EVGARTX 2080 SUPER FTW3 ULTRA GAMING30213954No
EVGARTX 2080 SUPER FTW3 HYBRID GAMING29113940Attached 120mm AIONo
EVGARTX 2080 SUPER FTW3 HYDRO COPPER GAMING291158.540WaterblockNo
GainwardRTX 2080 Ti Phoenix/Phoenix GS29211250No*
GainwardRTX 2080 SUPER Phantom/Phantom GLH29213054No
GalaxRTX 2080Ti SG Edition30811147No
GalaxRTX 2080Ti HOF33014557No
GalaxRTX 2080Ti HOF 10th Anniversary Edition32016558No
GigabyteRTX 2080 Ti GAMING OC 11G286.5114.550Yes
GigabyteRTX 2080 Ti WINDFORCE 11G/WINDFORCE OC 11G280.4116.540Yes
GigabyteRTX 2080 Ti TURBO 11G/TURBO OC 11G267113.735Yes
GigabyteAORUS RTX 2080 Ti TURBO 11G271112.536Yes
GigabyteAORUS RTX 2080 Ti 11G/XTREME 11G290134.360YesConfirmed
GigabyteAORUS RTX 2080 Ti XTREME WATERFORCE 11G29013140Attached 240mm AIONo
GigabyteAORUS RTX 2080 Ti XTREME WATERFORCE WB 11G291.315928.7WaterblockNo
MSIRTX 2080 Ti VENTUS GP/11G/11G OC/OCV126811250Yes
MSIRTX 2080 Ti SEA HAWK X26811441Attached 120mm AIOYes
MSIRTX 2080 Ti LIGHTNING/LIGHTNING Z32814363No
MSIRTX 2080 Ti GAMING TRIO32714056.5No
MSIRTX 2080 Ti DUKE 11G/11G OC31412050No
MSIRTX 2080 Ti SEA HAWK EK/EK X305169.341.5WaterblockNo
MSIRTX 2080 SUPER VENTUS/VENTUS OC26811450Yes
MSIRTX 2080 SUPER AERO26511440Yes
MSIRTX 2080 SUPER GAMING TRIO/X TRIO32814056.5No
MSIRTX 2080 SUPER GAMING X TRIO32814056.5No
PalitRTX 2080 Ti GamingPro/GamingPro OC29211258No*
PalitRTX 2080 Ti Dual29211258No*
PalitRTX 2080 SUPER GR/GRP29213059.6No
PNYRTX 2080 Ti 11GB XLR8 Gaming Overclocked Edition30211438Yes
PNYRTX 2080 Ti 11GB Blower26711438Yes
ZotacRTX 2080 Ti Twin Fan26811338Yes
ZotacRTX 2080 Ti Blower26811338Yes
ZotacRTX 2080 Ti Triple Fan30811357No
ZotacRTX 2080 Ti AMP MAXX29813342No
ZotacRTX 2080 Ti AMP30811357No
ZotacRTX 2080 Ti AMP Extreme/Extreme Core32413659No
ZotacRTX 2080 Ti ArcticStorm29515830WaterblockNo
ElAntonius
Thanks for this!
The sapphire pulse rx5700xt is now listed at 254x135x46.5 mm. I’m thinking that’s gonna miss by the pcie corner exclusion?
Necere
NCASE
3,284
Thanks for this!
I will add it as compatible, but the height of the card at the rear corner puts it very close to the limit and therefore might make for a difficult install.
Reactions: ElAntonius
ElAntonius
Also the Asrock Challenger 5700s look to have been updated on their website to 281x137x42 mm. Might be a bit dicey like the Sapphire? What is with all these chonker amd cards?
Also thanks for compiling this...trying to plan a build is really a lot easier with this table
Necere
NCASE
3,284
They've changed the measurement to include the bracket, which adds ~15mm to the overall height. My list uses the measurements without the bracket, as this is the more common way of measuring cards.
How can I be sure that's what they're doing? By eyeballing it. Take a look at the retention flange of the PCI bracket, and compare the height of the card to that. The bracket is always the same, so you can get a pretty quick estimate of the height by comparing them:
The retention flange extends 13.3mm from the rear. You'll note that the card height extension A on the ASRock card is fairly close to the length of the flange, which is consistent with what we get (15.3mm) if we calculate it using the original 121mm height given by ASRock and subtracting the distance from the flange to the edge of the PCIe connector (105.7mm).
Contrast that with the EVGA FTW3 card on the bottom which is 139.3mm tall (without the bracket); the height past the bracket (B) is clearly much greater than the length of the bracket flange.
ElAntonius
That’s really good to know. That’s why a list like this is super useful for folks, i know I’ve been trying to figure out what aib cards are in play for my next build and it’s next to impossible to suss out.
2,669
2,793
Another one to add here:
PowerColor RX 5700 XT Red Devil
https://www.powercolor.com/product?id=1565160726
Looks like it is 300mm length, so probably does not fit.
Not only is it long but very tall, with the power connectors at the top of the PCB. This one I would guess is a no go for the Ncase. If you look at this page from PowerColor they have a couple other 5700 XT's that should fit no problem.
Reactions: FelipoG
FelipoG
40
Yes, makes sense. Just putting info so he can update the table.
Here is another one that is now available for purchase:
https://www.msi.com/Graphics-card/Radeon-RX-5700-XT-MECH-OC
232 x 126 x 46 mm
That one fits I think.
Necere
NCASE
3,284
232 x 126 x 46 mm
MSI 5700 XT Evoke is another to add.
Gigabyte Radeon RX 5700 XT GAMING OC 8G
Card size: L=279.85 W=114.35 H=49.55 mm
Source: https://www.gigabyte.com/Graphics-Card/GV-R57XTGAMING-OC-8GD/sp#sp
Added all of these.
FelipoG
40
Hey again
There are a few more from Asus, now available to purchase (at least in Germany).
Just to you to know I'm just posting all this because I want to check all 5700 models that are coming, for my V6 build :)
Sorry if I'm bothering all of you hehe
- ASUS TUF 5700 - https://www.asus.com/Graphics-Cards/TUF-3-RX5700-O8G-GAMING/
26.9 x 12.5 x 5.4 Centimeter
- ASUS TUF 5700 XT - https://www.asus.com/Graphics-Cards/TUF-3-RX5700XT-O8G-GAMING/
26.9 x 12.5 x5.4 Centimeter
- ASUS ROG 5700 OC - https://www.asus.com/Graphics-Cards/ROG-STRIX-RX5700-O8G-GAMING/
30.5 x 13 x5.4 Centimeter
- ASUS ROG 5700 XT OC - https://www.asus.com/Graphics-Cards/ROG-STRIX-RX5700XT-O8G-GAMING/
30.5 x 13 x 5.4 Centimeter
Brock
32
I’m sorry. Is there a list like this for previous version cards? I see an Asus 2080 ti oc isn’t compatible because of recessed power connectors. Is this the same for the Asus 1080 ti oc? Becauuuseeee I have one showing up on Monday. Lol.
Necere
NCASE
3,284
There is not.
Recessed power connectors mean the card is more likely to be compatible, not less. It just happens that those cards are still too large in other ways.
Is your card the 1080 Strix? Here's a post showing that card in the M1.
Brock
32
There is not.
good look man. Thank you. The suspense of getting this case is killing me. LoL
Bubmer
Hey now that the xfx thicc 2 is out you should add it to the list, although I'm 90% sure it's incompatible they really weren't lying about it being thicc
Nazirite
28
Really wish the 5700 xt Pulse was a better fit, would be an easy choice for GPU.
now have to decide between 5700 xt FE vs 2070 Super FE
