So as the title implies, I'm one of the million people planning a build inside the NCASE M1.
I'm trying to shave a little off the price of the system (needed another $30 to upgrade from the SSF450 to SF600) and I'm wondering if I could forgo some fans. My original idea was to have two ML120s at the bottom of the case (as intakes, I'm using an MSI Armor card so I figured it might need some extra air) and another two intakes mounted where the AIO brackets are, and then one 92mm slim Noctua exhaust out the back. I'd have the ML120 intakes spinning at maybe 20-30% of their PWM speed as I've heard they can get quite loud under heavy load, but the Noctua would most likely be spinning near 60%. Would I be able to forget about the bottom two intake fans while still keeping temperatures somewhat manageable, or should I just load up the entire case with fans and hope for the best?
Should probably mention, I'll be using the Wraith Spire cooler on the 1700 but I'll probably have the 1700 overclocked running at at least 1.2~1.3v at maybe 3.8GHz? Not sure what the voltage-temp correlations are for the 1700 as I don't have mine yet but I do know that I'd like single-core speed at least near 3.7-3.8GHz, I don't want to have too much of a single-core speed shock coming from my 5820K @ 4.3GHz.
Also, does anyone know when the AsRock AM4 ITX board is going to be coming out? I reaaaaaaaally don't want to have to buy the Biostar.
Edit: Parts list for those who'd like to peruse it (https://pcpartpicker.com/user/jaka2015/saved/bym999) I can take suggestions on all parts other than the SSDs and the GTX 970, as I already own those.
