Will this build fit in the NCASE M1 V5? i7-9700k & 2080 Ti
meganfarr
Hi, I'm looking at building my first PC and was wondering if I could have some input on this configuration:
NCASE M1 V5 Black & Vented Aluminium Panel
i7-9700k
Gigabyte Windforce 2080 Ti
ASRock Z390M-ITX/ac Mini ITX LGA1151 Motherboard
Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz RAM
NZXT Kraken X52 Rev 2 CPU Cooler
Silverstone 700W 80+ Platinum Fully-Modular SFX PSU
Samsung 970 Evo 500GB SSD
Seagate Barracuda 2TB 72000RPM HDD
2 x Noctua NF-A12x25 120mm Fans
The plan is to make the two Noctua fans below the GPU and have the two fans from the NZXT Kraken X52 inside the case as intake...
Just wondering if this will all fit, will it be sufficiently cooled and any changes you'd recommend?
jtmsrl
31
that’s a really standard configuration for an ncase, you should be able to look up in the forums and find lots of information
Zutko
24
Only problem I see here is the conflict between fans on you gpu and noctua under them. You basically will be pulling air from gpu that wants to take in the air = negative pressure. If you are to put fans under as exhaust, then remove fan shroud from your gpu and let noctua fans pull hot air from your gpu. And install small fan at the back as exhaust as well...
