Update! PSLATE CABLES CAME IN!
I took better glamor shots lol
Hello, I wanted to post up my new & first SFX build.
Specs:
However, I really wanted to mount my 120 MM Radiator in the bottom position where there is an opening for a 120mmx25mm fan.
It fit okay but I messed up on the AIO choice and it was way to think even with a 120mmx15mm fan on top.
In the end I went to the hardware store and got these screw spacers (1/2 inch~ 12.7mm ) to lift the medium "top" hat off the bottom plate.
I think this looks much more balanced then the mounting of the large top hat on top or the bottom and a unique look to this case. I am pretty happy with this build!
Side note: I really want to get custom cables for this so the CPU side doesn't look so congested. I tried to keep it as tidy as possible though.
Thanks!
Specs:
- Silver Loque Ghost S1 & 1 Medium Top Hat
- Intel I7 9700K
- NVIDIA RTX 2070
- Phantom Gaming z390 ITX
- HyperX 16 GB 3200 mhz (2x* GB)
- Samsung 500 GB EVO Plus M.2
- Samsung 1TB QVO SSD
- 600W Corsair Platimun SFX Power Supply
- 1 NF A12X15 PWN Fan
- 1 NF A12X25 PWN Fan
- NZXT M22 120mm AIO
Thanks!
