Hello, new here..
I recently ordered Loque Ghost S1 case, with 1 large top hat and 2 medium, i haven't received the shipment yet but i was hoping for advice and guidance on purchasing the right hardware for now, i'm very rusty and the last time i built a pc on my own was in mid 2000s![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Well first thing for the build is basically i want to have at the bottom a medium hat for storage, and the large and medium at the top for the 120mm fans where the radiators are sandwiched in between for push pull effect, does that sound right? or should i place a set of fans at the bottom?
This is the list of hardware..
Motherboard = ASUS ROG Strix X470-I
CPU = AMD Ryzen 7 2700X
GPU = EVGA GeForce RTX 2080 Ti ( evga hydro ftw 3 OR kingpin )
CPU cooler = NZXT Kraken M22 120mm ( that would mean one radiator each for cpu and gpu at the top )
RAM = Corsair LPX 32GB (2x16GB) 3200MHz
PSU = CORSAIR SF750 750 Watt SFX 80+ Platinum Modular ( ..overkill? )
Storage = 2 ssds wd blue 2tb (raid 0) and 1 hdd wd gold 12tb
i would also like to replace all radiator fans with Noctua NF-A12x25.. that would make four 120mm Noctua fans...
I was also told to get this Noctua NA-SFMA1 to fit the Noctuas..??
I'm planning on buying each component separately and use some of my current pc hardware until its fully finished.
What do you guys think?
Thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance
