The PSU bracket has been slimmed down quite substantially, is reverse mounting the PSU still possible with the new design? I see two screw holes, but will it be able to support the weight?Mohoh good news then, I think you seen the latest KS update? ?
We milled out a 3mm deep area on the inside part of the performance panels (and top panel), so you'll have 3mm on each side (not all the way across the entire length/height, but enough for memory or CPU block/Cooler). If they are above 51mm & below 54mm, you'll have to install them after assembling the shell & core.
Also did some final improvements to the core:
These changed don't affect production schedule at all.
