- Jul 19, 2015
- 817
- 1,351
at this point i'd settle for x8/x8
In my case it would enable me to build out a system w/ a single slot GPU (iirc there are 1050Ti's & the 1070 Katana that are single slot) and throw in a 10Gb SFP+ / XFP NIC w/out having to use a bifurcation compatible mobo and riser or moving to a larger chassis (currently an ftz-03 mini) for my desktop. Maybe i will make my peace and end up w/ a beige Cerberus some time down the track instead though.it would allow users the option of dual GPU
I wonder what the dev cost would be to go directly to someone like @ASRock System and have a Mini-DTX board designed from the ground up on contract.
@SaperPL My M-DTX design(s) (the 3D rendered orange one you included) was based on official M-DTX dimensionsI totally understand wanting the board shorter though. That board was designed during the Z77 chipset days - a lot has changed towards component integration since then!
Yup, it followed the horrific CPU socket location of the contemporary boards at the time :/
But it was never for what we think it's good for, but how many Upper Management expects to sell.
Professional CAD users could have a single slot Quadro for modeling and a dual slot Tesla/Titan for offloaded rendering.
Tens of Thousands, probably.
Shuttle has been using DTX boards in their barebones for years (the 240mm wide ones, with 4x DIMM).
I approached them but they do not sell the motherboard alone.
The Shuttle boards aren't technically DTX, as they are quite a bit deeper. DTX is the same depth as ATX/mATX (244mm), but you can see the difference compared to mATX:
Mounting holes don't match the ATX standard either.
I want that dual socket board.Well, gigabyte still makes the correct size for this:
Asrock makes those slightly bigger in the other dimension as well though:
Btw, I wish I had bought this board/barbone when it still was floating on the ebay:
I've got the CPUs and memory for this laying around ;p
I feel like this would be the first point on a roadmap to having this board manufactured. The question is if we get the quotation from them, can we somehow fund a prototype batch that we would then send to reviewers and not "hug" for ourselves.
Because making prototype run for single generation just for us right now doesn't move anything forward and if we can't do anything with that batch, then it would convince board vendors even more that it's not worth trying.
I think the way to make this happen would be to compile a selection of compatible cases, build hype around the format and then crowd source.
