lyf007
Support for two 3.5" HDDs when using the horizontal GPU mount...
Your GPU will be inverted (aka upside-down), and if more than 175mm or so in length it will interfere with a 240 or 280 AIO...?
@Wahaha360 , please correct if I am wrong...?
Up to 235mm *horizontal GPU support, up to 4 slots, cable exit through the back
Deep ITX Epyc mobo could fit in this chassis as well...?
140mm AIO for the CPU, shorty GPU (RTX 3070 @ 232mm seems the best bet right now?), & a bunch of SSDs; all in a 14.5L package...?
Emm, I wonder if I can take the space of aio and use it for a 3.5. 140 aio should be enough for my 3600x but I have a full size gpu.
roscoejp
Can you flip it vertically so you don't have a hair braid of cables running from the top/rear of the case toward the table?
Sen
40
47
sen.lol
I emailed EK and they said there will be a 280mm AIO coming out soon ! Waiting on that to replace my 240
Glad I went with the NH-U12A to tide me over then, much easier a thing to resell than an AIO.
Will there be a way to fit a 3.5" HDD without blocking space for full length cards?
2,195
2,212
Norway
@Wahaha360 A question regarding the vertical GPU mount: does the case come with extensions, or is the opening in the bottom meant to facilitate tilting the case over to plug in/remove cables "easily"? And what is the maximum length for the connector+cable bend radius? In the pics it looks pretty short, which is less than ideal for DP connectors at least.
Marvelm
232
106
Poland
Not really on the ATX PSU.
The Kraken CPU block is 80mm tall, even taller than the Noctua L12S, to keep the case small, decided not to support it.
Hmm, I believe Kraken block height is only 53mm (for the X62) or 55mm (for the X63), 80mm are the two other dimensions. You can see that on the photos when the block is roughly the same height as the radiator+fan combo (30mm rad+25mm fan)
Reactions: DrHudacris
Kit
163
75
Looks freakin sh'exy
Any ideas when we will get a compatible 280mm AIO list?
D
Deleted member 23607
Guest
EK needs to get the D-RGB 280 EK-AIO on the Newegg (US) webstore...!
Agreed. It's interesting they decided to silently release it to Asia without trying to roll it out in the Americas / Europe.
Qu1ckset
199
217
Toronto
Well i initially planned to get the FormD-T1/Sidearmd, but didn't get on the first batches, then got intrigued by the vertical cases because of the NZXT H1, then decided to wait and see how the FormD-P1 would turn out. Bought a 2020 Blade 15 Adv as a temp system while i waited , and im glad i waited, i think im going to preorder this case day one, i love the flexibility, and looks of this case, and think it looks even better then the P1 early renders.
