Other Meshlicious feet advice
Dawelio
Awesomeness
524
440
Hello all,
I'm having a bit of difficulty on deciding which feet I should use with my Meshlicious case and hence wanted to ask you all for advice.
Now I'm fully aware that aestethics are highly subjective, but it doesn't hurt to ask and see what the community thinks overall looks best to them.
A
or
B
Please excuse the poor overall quality of the images, I'm far from even being a hoobyist photographer.
Thanks,
Dawelio
SiKiaTriK
166
147
First ones imprint a bit of a distinctive subtle touch while second ones comply with the overall smooth mate black colour of the case. For me the second ones win because they could perfectly would have come from factory.
Reactions: Dawelio
tinyitx
2,279
2,338
A is more expressive, elegant and assertive. B is more subtle, quiet.
That little silver ring detail of A would probably draw some attention to itself where attention should be given to other parts of the build.
Both look like they are of the same height? I am more a pragmatic person. I would prefer the taller one (if there is one) to give better case bottom airflow. If not, I would prefer B.
Reactions: Dawelio
Neathdrawls
264
485
I actually like Option A. Those are aluminum feet yes? I have a bunch of those at 25mm tall, and I find that they look good with a lot of black cases.
Reactions: Dawelio
Dawelio
Awesomeness
524
440
Interesting point of view and you're kinda correct, A is 15mm tall and B is 15.5mm, so slightly taller, but barely noticeable though.
They are aluminium feet yes. Yeah, it's a personal preference in the end :)
