News Low profile MSI GTX 1050 ti
I apologize if this isn't news worthy. There looked to be a lot of interest in a card like this so it seemed relevant.
A low profile GTX 1050 ti has shown up on MSI's website. It's a dual fan cooler that occupies two slots, slot powered, and has dvi/HDMI/DP outputs. I've not seen any announcements about it and couldn't find it for sale anywhere yet.
https://www.msi.com/Graphics-card/GeForce-GTX-1050-Ti-4GT-LP.html#hero-overview
Reactions: aquelito and EdZ
Ceros_X
748
660
Wish we could get a benchmark / noise comparison between the LP 1050Ti and the single slot XFX 460. Thanks for posting the info!
4,793
The NVIDIA software may be detecting FurMark and downclocking on purpose.
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
Thank you for the info. Any chance you could post a photo of the low profile bracket, and the back of the card? Does it look like unsoldering the DVI port is something that someone would ever want to do?
EdZ
Virtual Realist
May 11, 2015
1,578
2,108
Another curious detail, the core clock in furmark doesn't seem to go higher than 1370MHz. However, after about 30 minutes of gaming, I noticed the clock was consistently at 1911MHz. Not sure how I can achieve those clocks in furmark.
Both Nvidia and AMD refer to Firmark as a 'power vampire' or 'power virus', and actively prevent cards clocking up when it is running in order to prevent damage.
robbee
n3rdware
887
1,403
Happy newyear everyone :)
Unsoldering seems possible but the DVI has a lot of connections that you would need to desolder. I've marked them with the red square.
Reactions: Lone
TheGooseIsHere
65
59
Shame they made the 1050ti significantly longer than the 750ti (14.6cm vs 18.2cm) :(
Renders it more undesirable for ultra sff builds :(
robbee
n3rdware
887
1,403
What about the solder points for the metal shield?
That might be for advanced solderers only. I can count 6 solder points. Three of them on the side of the pci bracket could prove very difficult, as they're 'beneath' the shield and one of them is only a few milimeters away from the DP. It's too small to get a good picture of so I hope my explanation is clear.
Reactions: jeshikat
robbee
n3rdware
887
1,403
Looks like I was a little wrong. There's more desolder points, but it doesn't seem so hard after all. Here's a detailed picture:
robbee
n3rdware
887
1,403
I guess the most important question would be: how does it perform, and would you buy it again?
It performs well enough for casual full hd gaming and couch gaming. It might be a tad expensive but the SFF options are limited. I have to admit that I'd been waiting a while now for a small, low power and hevc capable gpu that allowed for some gaming. So I didn't really mind paying a little more. Yes, I would buy it again.
Reactions: Lone
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
I have a wall of quick and dirty comparisons in my benchmark rig for the EVGA 1050ti 4GB.
At Ultra, 8x AA, 2160x1440 it gets 1013@24 fully warmed up. I'd love to know what this little guy does.
As for Furmark, this is what my 1050 does:
So it seems that at least in Furmark the two GPUs are compareable, which is nice. I love the 1050ti. Flawless FPS in Overwatch at 1440p and Civ VI, and with some settings tweaked it does great in Fallout 4 too. Maybe noone else plays these games, but that's what I love so it is great for me! :D
It is a bit sluggish in Resolve and Premiere though, noticeable from the 1070 (which is 6GB VRAM) but it's not bad.
7,730
Looks identical to Gigabyte's 750ti LP (same IO and all). The cooler isn't too loud, but the double stacked rear IO// ugh
VegetableStu
1,949
2,619
Kinda curious: why are full sized DP ports used for those LP GPUs instead of mini DP? Maybe ditto HDMI
7,730
I wonder if the cost of bundling adapters is more substantial than the cost of implementing full sized ports (and that annoying doublestack DVI)
VegetableStu
1,949
2,619
Actually I wouldn't mind if they used super short full DP extension cables and soldered the card end directly to the card without the head...
