Hi all,
I am thrilled to have discovered this forum. I did a search for a i9-9900 here, and haven't found much, so I apologise if this has been discussed already. I have so far attempted only one SFF build (now I know the proper term), using a DIY scaffold of Aluminum T-profiles as a 'case' (500x300x100 mm outer dimensions), as most standard SFF cases seemed too boxy. I based my box around a i7-6800K, an Akasa Nero LX, a micro-ATX (ASUS X99-M WS/SE), SIlverStone SST-SX500-LG PSU, and a GTX1050 GPU. I just arranged the components to make as flat as I could, and the box has been working well for a year so far (Inventor, movie rendering, I am not a gamer though).
Well my laptop just died, and I would like to try a i9-9900K mATX build, and this time to make it more portable and more organised. I think I can shrink it to 400x250x80 mm, i.e. to take on carry-on, and use it as a chunky 'laptop' (no battery ). The only sticky point is the low-profile cooler. Are there any that are known to work with the i9-9900K (no overclocking)? I've been looking at 120 CFM+, and those were all monstrous, whereas I am after something thin, flat, and wide. What also confuses me is that the i9 is rated at 95W, whereas my current i7 is rated at 140W. The i7 has been doing just fine with the Nero LX, and yet I was advised against this cooler with the i9. Perhaps I haven't been loading the i7 that much, and thus haven't noticed any issues? May be I can just swap the stock 140mm fan on the Nero with a much larger one, and focus the air better with an adapter funnel of some sort (3D print)? Any comments would be much appreciated!
