Ghost S1/DA2 S i9 990K(S) build
xy01xy01
I am planning to build a system with either the ghost s1 or the streacom da2 case. this system will be used for gaming and media streaming for the most part. i consider using the following components:
  • i9 9900KS or i9 9900KF, depends if i can get a reasonable prized i9-9900KF; would do u prefer a newer i9 10980XE making it more ready for future games, but slightly slower than the i9 9900K(S) in current games??
  • i prefer air cooling. read the alpenfoehn blackridge with a noctua Nf-a12x15 would be the ideal solution for cpu air cooling right now?
  • corsair sf750 platinum for power supply
  • with the s1 i would propably use 2 small top hats. 1st for 2 120mm noctua fans on top and the 2nd for 2 samsung 860 pro bottom. which low profile fan whould u rec?
  • i am unsure which gpu i whould choose: geforce rtx 2080 ti or the newer titan rtx. and standard cooler or any changes here?
  • for ram and board i would prefer to use the g.skill trident z neo 2x32gb ram with an asrock asrock z390 phantom itx mb and a samsung m.2 970 pro?
  • for the ghost s1 any additional fans in the case?
any recommendations and comments welcome. thank you
xy01xy01
i am planning to build a new sffpc with the ghost s1 case. i will use it primaraly for gaming, media and browsing. i choosed the following components:
  • i9 9900ks
  • 2x32gb corsair vengeance ltx 3600mhz c18
  • m.2 500gb 970 evo pro, m.2 2tb 970 evo plus, sata 4tb 960 pro
  • geforce rtx 2080 ti evga kingpin or zotac amp extreme
i am thinking of creating a custom water loop system to cool the 9900ks and gpu, as i dont like the look of aio's and think a noctua nh-l12s air cooling would probably not enough. i thought of the xspc tx120mm or 240mm ultrathin radiator, a cuplex cryos next for cpu cooling and kryographics next rtx 2080 Ti ful body cooler. i would love to stuff the radiator in a medium tophat and keep my ghost s1 as small as possible. for radiator coolers i would choose 120mm noctua.
any thoghts if this is possible? thanks
2,581
2,693
The XSPC TX is still 20mm thick and the medium tophat is only 25mm, no way to fit a fan. A 240mm radiator can just barely cool the setup you propose, I don't see anyway you can do it without using a large tophat.
