I was a big fan of the First 3 iterations of the chassis. Never had the financial ability to purchase one and am yet looking for one which is how I stumbled onto this thread. If I might add, there may be a few people who may be working with a BeQuiet! Shadow Rock LP or a Cryorig C1 so the height limitation would be a little too bad for such an amazing chassis and it's predecessors.
Do you see any possibility to include a couple of drive brackets for those who'd like to stack 2.5" drives to act as add-on storage? There already is options for 2x2.5" under the motherboard tray though where is the third 2.5" mount? When do you see this project materializing? What about color options?
Personally, I don't see it being an issue. I've never supported CPU coolers greater than 65 mm in height. The BeQuiet! Shadow Rock LP should actually work if used with a slim 15 mm height fan.
The third mount (and possibly fourth) is at the front of the case. That's why I'm going to list support as 2+ 2.5 inch drives, or something along those lines.
The L4 prototype is in production, but a couple weeks away. The L4 actually has one part that has some features that are machined, so this adds to the leadtime. Estimated availability is Q1 2017, but who knows. Not sure about colour options yet.
Nice seeing you back after a long time thoughHow've you been since?!?!
I've been doing great, thanks for asking! I appreciate your interest in my project.
The new case looks great!
But I have the same concern as Lutfij on the cpu cooler height limitation. I personnaly don't need tthe space for SSDs on the back of the motherboard. Would it be possible to have a system to elevate the MB only when needed, and if you don't, you have more height for the cooler.
Thanks! What CPU cooler are you wanting to use? Unfortunately, your suggestion would not be feasible.
