Motherboard List of motherboards with angled Pcie slot (-PIO)
milesvw
158
109
The Zillion H610 is $73 on AliExpres through Sep 7th 2024
https://www.aliexpress.us/item/3256806894864240.html
(And I'm not saying it's a good idea, but a 12700KF new on Amazon was $166 yesterday https://www.amazon.com/Intel-i7-12700KF-Desktop-Processor-Unlocked/dp/B09FXKHN7M).
I'm still going 12500T ($80) on the JW H610, with Powercolor Fighter 6600XT ($150), it's the smallest decent card with full HoloISO support (7xxx series doesn't have SteamOS support yet.)
They just offered me $10 on this, if you want to run the GPU off a seperate 500w Flex PSU https://www.ebay.com/itm/386355131466
1,255
That’s not AM5…? b660i is LGA1700 lol
Oh yep you worked that out- I clicked first because you got me all excited
milesvw
158
109
As an apology accept a possible case. I had to make 2 small cuts, but it seems to fit quite well. I am sorry I forgot to take a picture of the back, I cut along the line of the PSU hole top and bottom. I used 11mm (7/16") worth of standoffs (Here made from an M3 thumb nut and an M4 hot-press insert). This got it up above the cutout for the Flex ATX power supply and the existing case standoffs.
ARSYLID Q32 ITX A4 Computer Case 3.2L https://www.aliexpress.us/item/3256806112050038.html
Reactions: SFFMunkee
Clem075
Hi, what power supply do you use ? I can't find anything with this power connector, do you use some sort of adapter ?
milesvw
158
109
I have an Alienware 240w laptop power supply (slim GaN style) and I use a soldering iron to attach this 4-pin plug: https://www.aliexpress.us/item/2255800396801176.html
The 240w supply is for the 4060 GPU, a P620, RX6400, or Dell RX6500 work fine with a 150w power supply.
