Motherboard List of motherboards with angled Pcie slot (-PIO)
R3venger
35
44
Hi all together,
after purchasing one of the motherboards with a angeled pcie slot, using the taobao shopping guide in this forum, I wanted to give you the direct links to the different products.
Those motherboards are currently only availible in china as far as I know.
Let´s get started.
Asrock H110M-PIO (449 Yuan / 65,45 USD )
https://world.taobao.com/item/545306287162.htm?spm=a312a.7700714.0.0.R7hLKs#detail
ECS Elite H81M-SI01 (188 Yuan / 25,49 USD)
https://world.taobao.com/item/52417...&spm=a312a.7700824.w4002-9952499787.31.QA7SDQ
ECS B85M-SI01 (208 Yuan / 30,32 USD)
https://world.taobao.com/item/524179123064.htm?fromSite=main&spm=1101.1101.N.N.c40d862
ASUS B150M-PIO (690 yuan / 100,57 USD)
https://world.taobao.com/item/535467249119.htm?spm=a312a.7700714.0.0.T1USiR#detail
MSI B150M ICAFE PIO (680 Yuan / 99,12 USD)
https://world.taobao.com/item/536530550448.htm?spm=a312a.7700714.0.0.T1USiR#detail
GIGABYTE B150M-PIO (670 Yuan / 97,66 USD)
https://world.taobao.com/item/535509173260.htm?spm=a312a.7700714.0.0.T1USiR#detail
GIGABYTE B85M-PIIO-H (299,99 Yuan / 43,73 USD)
https://world.taobao.com/item/545076947415.htm?spm=a312a.7700714.0.0.T1USiR#detail
GIGABYTE B150M-PIO-H (799 Yuan / 116,46 USD)
https://world.taobao.com/item/541636333614.htm?spm=a312a.7700714.0.0.T1USiR#detail
GIGABYTE B85M-PIO-H (699 Yuan / 101,89 USD)
https://world.taobao.com/item/541617299691.htm?spm=a312a.7700714.0.0.T1USiR#detail
GIGABYTE B85M-PIO-H (299 Yuan / 43,58 USD)
https://world.taobao.com/item/545653888647.htm?spm=a312a.7700714.0.0.T1USiR#detail
ASROCK B150M-PIO (650 Yuan / 94,74 USD)
https://world.taobao.com/item/536615793573.htm?spm=a312a.7700714.0.0.T1USiR#detail
775
758
Thanks. Just so you know, we have a Wiki, where listed information, like the motherboard name and features, would be excellent. It can be navigated to via the "Wiki" link in the navigation menu at the top of the page.
Chrizz
74
81
Wow, I didn't know these existed, and they're reasonably priced too. It definitely makes sense that the PCIe slot is at the other side than usual to point the GPU- and CPU-fan in the same direction.
If these are actual ASRock and GIGABYTE boards, why do they only sell them in China? There would definitely be demand for them in the rest of the world.
EDIT: Wow, most of the GIGABYTE ones are even thin mini itx!
R3venger
35
44
Yes the Gigabyte and the B85m-SI01 and H81m-SI01 have a thin itx layout, but a 24pin connector.
Because most of this mainboards are for aio pc´s and aio barebones. The chinese guys detached them and sll them. Or they buy a lot of them at once.
SPK
Did you check the PCI 3.0 x16 slot functionality ? If you have, please tell if it is functioning optimally. Can it support a GTX 1080 8+8 pin ?
R3venger
35
44
Mine is working at Pcie 3.0 16x :)
But you can send me your gtx 1080, just to make sure :D
SPK
Thank you very much for the response. Is your GTX 1080 single 8 pin or 8+8 pin ?
Also, does it allow for GTX 1080 overclock.
CPU over-clock is unavailable on B150 chipset
Also, please tell about the drivers and BIOS Updates for GIGABYTE B150M-PIO-H
SPK
R3venger
35
44
I have just bought the H81m-SI01 to check if my idea and the shopping guide works.
Currently there is a GTX 960 pluged in and a XEON V3 1230 on top.
The bios is an UEFI in my case.
About the other boards you can find info at the website of the manufacturer
SPK
Thanks for the response
There is no information available about the GIGABYTE B150M-PIO motherboards on GIGABYTE website - so no BIOS update source.
Please tell the maximum DDR3 speed supported by ECS Elite H81M-SI01.
What do you think can be the best 88W TDP small form factor cooling solution for this motherboard for an HTPC build ?
Colinreay
198
490
Woot, this is great, are there any that are a full 16x? I can't find any in the list.
I'm pretty sure all of the motherboards listed have physical PCIe 3.0 x16 slots running at full bandwidth. Sorry, I probably misunderstood, but is this what you are asking?
I'm guessing there are no BIOS's available on Gigabyte's website because this is a very OEM oriented motherboard, and they would likely contact Gigabyte directly instead of going through their website and downloading them to flash drives or another device.
Since the ECS has a H81 chipset which doesn't support Memory overclocking AFAIK, you'll be limited to 1600 MT/S max ram (1600MHz).
I think this answer depends heavily on how much cpu cooler clearance you'll have. How far is it from the motherboard tray to the side of the case? Does the CPU cooler have a dedicated cutout in the panel to get air from, or does it have to pull it from inside the case? For example, look at K888D's testing of fans directly next to a solid surface. If you don't have vents, you'll want at least 20-25mm of space between the cpu cooler fan and the side panel, maybe even more.
Check this thread for more info.
GentlemanShark
Asus RMA sucks
Marsupial Computing
Dec 22, 2016
358
148
if you look at this board and then compare it to something like this, it looks to me like the B150 has a smaller slot, but I could be wrong. Also, for the memory speed, most manufacturers state 1600 as the max. (source)
Colinreay
198
490
The PCIe slot looks to be a full size slot, just without the PICe retention clip at the end of the slot (for obvious reasons, as it is at a 90 degree angle.) Keep in mind this looks like a custom form factor that is bigger than mini-itx (look at the RAM slot size compared to the board.) On a mini-itx board, those RAM slots would take up the whole width of the board. Because the mobo is bigger, it makes the slot look smaller.
For RAM, I believe I said 1600? I thought that was the JDEC standard (which replaced 1333 for DDR3), which was the highest Intel officially supports w/o overclocking.
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
http://www.jetwaycomputer.com/NF592.html
Interesting format : almost thin mini-itx.
Inversed PCIe x4 slot.
GentlemanShark
Asus RMA sucks
Marsupial Computing
Dec 22, 2016
358
148
Ah that's why. The board is longer toward the ATX connector and it threw off my reference.
