Lian Li/DAN A4-H2O
MattyKHZ
72
21
Can I confirm the alphacool lt240 will fit as not on the list and got one when intending to purchase the formd t1 as it was recommended for that….
EthanFANG
Hello DAN, So the PCI-E cable is from LINKUP with a length of 18cm? If I use the RTX 30 FE, with the position moving outside, will 18cm be enough long for my case?
SimoxTav
Hi,
my B450 has no type-e connection for USB-C front I/O and the internal 20 pins connector is a 3.1 gen 1. If I use a converter from the 20 pins to the type-e (like the one mentioned here), am I able to reroute the USB-A port to the internal USB 2.0 port (with something like this)?
astr0s
Long time lurker here. Received my A4-H2O and moved my NR200P setup to it today. I routed my X53 above the PSU, no kinks or anything. My 3060ti Gaming X Trio does protrude 0,5-1mm out from the front, but the plastic gives a little so the front panel closes without an issue (and I did remove the washers from the rad, so the top panel closes..). Also, stuck a 2,5" to the bottom after fighting with the cables for a little while. Custom length cables, especially for the GPU, would help building drastically. Overall very impressed with the case and quality.
  • 8700K
  • Z370N
  • 32GB Vengeance LPX
  • Kraken X53
  • 3060ti Gaming X Trio
  • 2x 1tb m.2
  • 2,5" hdd
  • SF750
dondan
1,970
8,311
NZXT Kraken X53
Radiator 30mm
Fan 26mm
Is it installed without any problems?
Should fit
Hi,
Better use this:
SimoxTav
Better use this:
Thanks for the reply Dan!
Are you suggesting the extension because there is no room for the adapter in place or because the 20 pins cable is enough to have both the USB-C + USB-A connectivity (so the Type-E is an alternative to that)?
dondan
1,970
8,311
Forgett my answer i did not get your question. Yes it will work with the adapter you linked.
