Production J-HACK PURE XL - 6.5L
Sam
25
What if you keep design the way it is and PSU position, just increase the length by 51mm so it is 270mm in total. Would be exactly 8.04L. I think new front room might accommodate a 92mm or 120mm AIO also.
Weredawg
119
162
So basically a slightly smaller SG13
Sam
25
Much smaller, from 11.5 to 8.04L, that's Dan A4 territory. There is no case on the market without pcie riser that would fulfill this gap. I had SG13, lots of wasted space, so I switched to Dan. PURE has a much trimmer design.
Weredawg
119
162
Isn't that what the LZ XTD basically is?
Thehack
Creator
Mar 6, 2016
2,818
3,673
J-hackcompany.com
I'll be using this as my main pc. Will be using external Distro 400 kit to power my 2600x and 1070.
Got the choten by scythe and it's a great cooler.
Thehack
Creator
Mar 6, 2016
2,818
3,673
J-hackcompany.com
So there is a bit of a panel gap, about 0.5mm.
It'd be hard to engineer it out. So question:
Small panel gap, or no gap but you have to deal with more screws?
Brude27
384
878
Your painted prototype is gorgeous, and the gap isn't noticeable with the two-tone black and white color scheme. I'd say the only reason to change the design is if there is flex at the gap points when picking it up and moving it around, or if turbulence noise is generated in the gap areas.
Thehack
Creator
Mar 6, 2016
2,818
3,673
J-hackcompany.com
There is no painted prototype yet :D. Are you referring to the render?
Brude27
384
878
Wow... yes I was referring to the render, which is a damn good one! I legit thought that was real, haha! But what I said still stands. The black and white two-tone will hide any gap that size from the human eye as long as light isn't behind it.
Reactions: Weredawg
Weredawg
119
162
I thought it was real too! ?
Reactions: Brude27
2,682
2,807
I was also fooled, I have to say that @Thehack renders look really life like.
