Have you also tried c14s as exhaust? That is the stock fan setup when you buy it. Recently put my build together but I'm in doubt what is the best fan setup (c14s intake exhaust and A9 rear fan intake exhaust with a stock strix rx 5700xt).Performed some tests with the ncase m1 comparing inverted versus normal case orientation and got some interesting results.
Very interesting, thank you for your test!
Did you face any issues when deshrouding and installing the KFA 2070 Super EX with the NF-A12x25s? Was it a very tight fit, did you have to bend anything or did it fit just fine? Can you still use the full front I/O?
I'm asking so detailed because I'd like to use a deshrouded KFA 2060 Super Ex with two NF-A12x25s for my build, but since the KFA card is a triple slot I was wondering if removing the shroud would provide enough additional space for (easily) using the NF-A12x25s and the front I/O. According to their product homepages the 2060 Super EX and the 2070 Super EX have the same dimensions so if you didn't run into any problems it should be fine by me as well.
Sorry for asking so many questions but it's my first pc build ever and I'm a little nervous about modifying a 400 € graphic card in my first build...
Really looking foward to your GPU + CPU stress and temperature tests and the sound profile video!
H
You can fit the front pannel with this setupDid you face any issues when deshrouding and installing the KFA 2070 Super EX with the NF-A12x25s? Was it a very tight fit, did you have to bend anything or did it fit just fine? Can you still use the full front I/O?
I'm testing myself today, since I'm free from work todayI Will try this setup soon! I have an a9 here, will do it soon!
You can easily fit it! I tried to film it but one handed it was hard.... -)
I will confirm if you can use the front pannel with it soon, I am almost certain that you can.
I advise on using zip ties to attach the fans on the heatsink, don't screw the fans on the case because they won't stay flush, you have some mm between the fan and case floor.
Did you do any testing? If so, what were your results? Currently I've been eyeballing the temps using afterburner and HWinfo64 while gaming. I'm using a stock C14s with the 140mm fan as exhaust only. I don't have any other fans in the case. My GPU is an ASUS Rog Strix 1080 ti OC gaming edition - stock shroud + fans.I'm testing myself today, since I'm free from work today
Will make a separate post about it, but to be short: use the 140mm on the c14s as intake (tested at 50% fanspeed i Believe). This will reduce temps of the cpu by 5-8 degrees and will drasticly reduce motherboard chip /vrm temps. The rear 92mm noctua (at 40%) as intake is way better than exhaust and reduces temps of the cpu by 4-5 degrees.Did you do any testing? If so, what were your results? Currently I've been eyeballing the temps using afterburner and HWinfo64 while gaming. I'm using a stock C14s with the 140mm fan as exhaust only. I don't have any other fans in the case. My GPU is an ASUS Rog Strix 1080 ti OC gaming edition - stock shroud + fans.
Between playing World of Warcraft, The Division 2, and Destiny 2 at 120mhz 3440x1440p my temps range from CPU 65-70, GPU 71-76c. That's with the house temp set between 20-22c. So it's not bad. I have the stock 140mm fan set to 1100-1200 rpm all the time.
I'm pretty sure that adding a 92mm noctua fan to the rear of the case as intake, and deshrouding the GPU and adding 2 x 120mm A12x25 noctua fans would improve those thermals! My guess would be by 5-8c maybe? I'm just waiting for Noctua to release their black 120mm fans.
very nice!Will make a separate post about it, but to be short: use the 140mm on the c14s as intake (tested at 50% fanspeed i Believe). This will reduce temps of the cpu by 5-8 degrees and will drasticly reduce motherboard chip /vrm temps. The rear 92mm noctua (at 40%) as intake is way better than exhaust and reduces temps of the cpu by 4-5 degrees.
Futhermore, this setup lowered gpu temps by 2-4 degrees strangely enough. Also, undervolt your gpu! My strix rx 5700xt undervolted by - 110mv reduced wattage from 190 to 155w roughly and fan speed from 53% to custom fan curve for same temps (68 degrees) as stock to 38% fanspeed.
Great great reduction in overall noise while gaming since every fan Above 40% speed = annoying. Especially the 92mm fan. I have that at 36% fan speed since 40% it starts to get a high pitch.
No just a regular noctua a9. Fits perfectly on the Asus b450i + c14s.very nice!
Are you using a slim nfa9 on rear?
Gpu stock fans?
Yep, that's the fan I have! Which gpu do you have? Search Google for some undervolt results from other users, sets an easy baseline for you to go with.I will look for some videos on how to undervolt the GPU properly. I've found a couple of videos about using MSI afterburner, but I haven't given it a shot yet. And I'm looking at this A9 fan for the rear intake / exhaust -
Ohhh you basicly only have to verify your strix can handle the undervolt (with heaven 4.0) and you are done!I have an Asus Rog Strix GTX 1080 ti OC Gaming.
