NCASE M1 6.1 Power LED is not working
dannyhaitran
Hi Everyone,
I hope someone from this forum or NCASE can help me sort this out.
I recently did a build with the NCASE M1 6.1 and I connected the NCASE front panel cords for the power switch and led to where it belongs in the MOBO but I find that the LED is not coming up. I made sure by following where the + and - go in the slots but still not working after double checking. Power switch works fine. Any Ideas?
Here are the parts : https://pcpartpicker.com/b/7jCLrH
Part List
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core
Motherboard :MSI B450I GAMING PLUS AC Mini ITX AM4
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16
Storage: Crucial MX500 500 GB 2.5" SSD
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME SSD
Video Card: EVGA GeForce RTX 2070 SUPER 8 GB BLACK GAMING
Case: NCASE M1 Mini ITX Tower
Power Supply: Corsair SF 600 W 80+ Gold Certified Fully Modular SFX
Case Fan: Noctua A12x25 PWM 60.1 CFM 120 mm
Custom Noctua NH-C14S
Danny,
elvendawn
60
24
Did you modify any of the power settings in the BIOS like enabled CEC or S5 mode? Some motherboard BIOS also have a lighting stealth mode that may disable the power LED too.
pakzboi
Same issue with my ncase m1 6.1. I am using all same components from CM NR200p. The led will lit after pressing and stay for 2-3 seconds while the PC is booting then after that it will turn-off and never notice it lit again or blink.
Necere
NCASE
3,261
If the LED comes on during boot then it's likely a BIOS setting turning it off. Look for LED settings in the BIOS and make sure stealth mode or a similar setting isn't enabled.
