Innodisk isn't a big name in memory, at least not outside of industrial uses, but they've risen in profile recently due to the fact that they're one of the only providers of VLP DDR4 RAM.
Read more here.
They offer both ECC and non as well as 2133 and 2400 MT/s, at least for mini SODIMMs.Guys, I found something interesting in InnoDisk cataloque. Much lower SODIMM DDR4 than 25mm.
288pin in description. I think it’s mistake.
ECC in description. I thinks it’s possible to order with non-ECC.
Why would it say SODIMM under the name then?Yes Mini DIMM is for embedded applications like high-performance routers, it's not compatible with any PC motherboard I know of.
Ah, that's a shame. Annoying kind of standardization.I think it's considered a type of SODIMM, but it's definitely its own thing and not interchangeable with normal SODIMM.
I'm in the same set of concerns, waiting on Dan HSLP-48 results and fitment. And although it's NOT a dealbreaker for me, I'd like to be able to overclock the RAM as well.I am interested in this (as I have stated already, here & elsewhere?), but I have a few concerns...
Primary concern, "Do I need these?" Test results for the Dan HSLP-48 will determine that...
Secondary concern, Ryzen compatibility & ability to overclock the RAM up to at least 3200, Ryzen has been shown to perform much better with higher clocked RAM...
So if #1 & #2 work out; I am down for a dual-channel set of 8GB 2666 DIMMS...
Maybe a set of 16GB DIMMs instead, depending on cost...
Would the 16GB DDR4 DIMMS come as a dual-channel set...?!?
Yep, I can buy one if you want. It's $81 for the smallest amount.Guys, any news about VLP SODIMM DDR4?
I sent pmYep, I can buy one if you want. It's $81 for the smallest amount.
Yeah, I've been having issues with them, however they seem to be more lenient now. Would you like to try to make a purchase on your behalf as well? They might be more willing to fulfill all of our orders if we order more.
