What's your current international shipping situation like? I'm in Australia but very keen to try one of these out.It'll be available on my website:
J-Hack: Small Form Factor ITX and SFFPC Store
Small Form Factor and ITX cases, accessories, fan adapters, and dc-dc power supplies.j-hackcompany.com
I'll be stocking some and seeing how well it does.
Does that mean you're not willing to do international orders or it would be a 'Buy at your own risk' if I decided to?Terrible
There is high package loss right now, so please wait until later this year to order. I just checked and it's about $25 to ship to AUS.
I'm trying to decide between one of these and a BlackRidge which is a bit more expensive (I think about the same as the IS-47+shipping)
Also just checking if you saw the second part to my post I edited in after around compatibility?
Fair enough! Thanks for the quick responses!I can't confirm compatibility yet, so I'll have to get back to you on that.
I am willing to do it, but buy at your own risk. Depending on your local availability, the price may be similar. In USA, the IS-47k will have much better pricing.
Decided to risk it! No other cooler suits my build as my memory is too tall for a BlackRidge which would have been the same price anyway.
I've had several packages delivered via USPS priority over quarantine and while it's slow it still gets here.
When do you expect to receive stock?
I'm very curious as to why the product recommend an exhaust orientation for the fan - surely in a case with no active cooling fans an intake through the side panel would be the most effective since the air it's intaking is cooler and in larger supply?
I've ordered an i9 10900f so will be interesting to see how this cooler copes with a 10 core/20 thread processor in a Velka5
I think so, unless you have decent airflow across the motherboard or and open air case then you'll want it drawing air from outside the case and blowing it onto the motherboard. Most cases this cooler is designed for are decently ventilated so it will not be an issue venting that air back out.I’ve been meaning to look into this. Is it better for noise and temps to swap the fan to intake pulling air in?
I'll be using it in a K39v2. Probably will test with the stock fan and a Noctua chromax 92mm fan from the L9A as well. Curious to see the results.I think so, unless you have decent airflow across the motherboard or and open air case then you'll want it drawing air from outside the case and blowing it onto the motherboard. Most cases this cooler is designed for are decently ventilated so it will not be an issue venting that air back out.
@Thehack any idea on shipping time? Will you ship orders on July 01?
Yeah in that case I definitely think the Noctua fan drawing air in from outside will be the best option. Although I guess we'll see when we get it and test it huh!I'll be using it in a K39v2. Probably will test with the stock fan and a Noctua chromax 92mm fan from the L9A as well. Curious to see the results.
Feel like we need another 47mm shoot out- what with this, the c7cu, axp-90(cu), black ridge and probably some others- which one is actually the best (especially considering that the axp90 and c7 have better compatibility). would be nice to have this solved objectively once and for all (though i suspect some of the differences are in the realm of cooler to cooler variation)
