Fully 3D printed custom case (update)
HgArg
21
38
BirdofPrey and 3lfk1ng, good :thumb::
HgArg
21
38
This is the main idea for the covers:
It has hidden ventilation holes:
3D printed:
(PLA, layer 0.25 mm, infiil 25%, with support).
Final dimensions: 342x210x90.5 mm, 6.5L.
I will test it. I think is enough for the components.
HgArg
21
38
Yes, is one of my ideas!!! This GPU looks really awesome!!! If I put a "real-size" Mini-ITX I can use the 1050 Ti without problem I think (I have another idea instead...).
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
With a sub 75-Watt TDP CPU, low-profile GPU, and those hidden ventilation holes throughout the covers (and side panels I take it) there is really no need for an exhaust/intake fan so a very silent build with the right CPU cooler and GPU.
What is the thickness of the case under 80 mm?
HgArg
21
38
Hi, I try to believe it o_O... I'm finishing the last details to assembly :cool:...
The chassis has 86 mm (maybe less than 84 mm in the redesign).
Bye!
