Concept FormD T1 V2.0
promaty
30
36
Yes, same layout and feature as T1.
Yea, to make room for cable coming out from the Top.
Can you make them come out from bottom? It's a bit weird having cables hanging on top.
Also for horizontal layout (including T1) why did you make bottom radiator position as the default one? Airflow is so much better when on top. I know you can flip it upside down, but having GPU hanging from pcie slot feels uncomfortable.
Psyduck91
69
62
If the design is like the Sidearmd, you might be able to able to flip the case so that the cables come out from the bottom. It would be a nice feature for sure.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
To support the same GPU height and AIO, you will need to make the case bigger in that layout.
So it’s less space efficient.
Reactions: Kit and promaty
Kit
163
75
Verticle, my 2 cents,
1) smaller foot print, even at slightly larger absolute size we still have the T1 for portability
2) possibility for better airflow design, less surface area facing down and both long faces perpendicular to the spine of are opended up
3) there are a number of horizontal cases in production already.
Keep up the good work!
Agree with the above, I think it would be a nice addition to your range from a design and aesthetic point of view.
I really like the foot print of this case which is perfect for people with low desk space!
Although I would put some design consideration into feet as this configuration is naturally going to be unstable....
Reactions: BRSxIgnition
the1q
37
54
Vertical for me. Would look amazing in the living room with that B&O aesthetic. This would move the needle.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Do you think it's possible to only use mesh as outer panels (check image below)? The MachOne looked incredible, would be nice to keep some design aspects if possible.
I like
promaty
30
36
One concern for vertical design, what if you use a wi-fi antenna? Does hiding the back panel with some piece of metal block the signal? ?
incunabula
89
135
Depends on what the mesh is made out of
If it's the same mesh on the T1, it's steel. The only saving grace here is that it will likely not be directly grounded, but a significant loss of signal quality could still be observed.
Reactions: Bonusround
Metroversal
224
492
Also, I think there's potential for another two-tone case like the T1.
Maybe having the Top and Bottom Panel contrasting the Mesh, I'm thinking something kinda similar to the SilverStone LD01 or the NZXT H510 Elite! Thoughts?
I can try to send you an graphical representation if necessary @Wahaha360
EDIT: Here's one variant inspired by NZXT H510 Elite.
Navic
587
1,341
I love it, but it kinda looks like a bus to me for some reason lol
