Concept FormD T1 V2.0
retrotics
I became inactive lately but one of the consideration for P1 is that it is supposed to be cheaper than the T1. Is this still a consideration for T1 Evo?
AFAIK, the P1 and T1 2.0/EVO have been merged, and the T1 2.0 will cost more according to Wahaha360, so it will be more expensive. This is probably just because the original pricing of the T1 V1.1 was difficult to keep with the increasing production costs, covid and the huge demand for the case.
tokes808
73
28
I am kind of confused about this new T1 V 2.0. Will this case change in dimensions to support larger AIO for example or stay the same size with other changes ? I prefer horizontal cases.
BRSxIgnition
381
544
Honestly, I'm not going to go ahead and get hyped for this case until we know more about it.
We need renders & info on changes, possible layouts, hardware support, etc. Especially if it's aimed to release in April, just 3 months from now.
As it is now, we know nothing definitively other than:
  1. There will be a vertical stand add-on.
  2. Goal is to perform cooler than the M1/Meshlicious.
Boil
1,253
1,094
I agree, more info needed...!
Reactions: RickNeclaDon
biopunk
249
359
Also:
2020-12-28: dual 240 radiator / AIO support for V2.0​
No increase in size.
T1 AIO prototype next week. Based on the noise and performance, I will change some more.
JDuval
93
166
I don't count this because it's still not clear if this is actually mounted to the case or not - so far any T1 dual loops have been custom loops with the rad on the side not even using fans, unmounted.
Plenty of people are using fans, albeit slim ones with only ~5mm between the radiator/fan combo and the GPU block.
Some have it free floating, some have made brackets to mount, myself included.
They could add official support for this relatively easily by making a bracket that mounts to one of the side rails or case bottom and producing a slim radiator, which they've stated they're working on previously.
Mao_Setzer
37
71
It seems clear for me.
Dual 240 mm support > inside the case integration with mounting braket or option to fix them.
Otherwise Waha will not officialy advertise it if its not the way he meant.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
I’m trying to decide on dual radiator support combo:
1) 280 on mobo side and 240 on top/bottom
2) 240 on mobo side and 240 on top/bottom
The trick is installation difficulty.
@fabio I will make sure the GTS240 will fit on the mobo side, maybe even the GTS280.
thelaughingman
1,413
1,566
same volume / dimensions for both configs? if same volume then then larger the rad the better. if different volume and single rad is the focus then I'd go 280 on mobo side. but for dual rad, I'd much prefer dual 240. having different size rad & fans is cumbersome to say the least.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
same
same dimensions.
I will make the case slightly bigger (135x220x330mm) for 25mm thick fan on the Top/Bottom TX240.
I did some testing, need 25mm thick fan on 20mm thick radiator at least for AIO to optimize noise vs performance
biopunk
249
359
Wouldn't it be tricky to route the tubing with the side rad on the mobo side? I imagine that the ports would face the PSU, and two rotary 90-degree fittings would require ~28mm of clearance.
I really like v1.1 layout with the side rad on the GPU side. Routing the tubing is pretty straightforward, just need a proper mounting bracket and a few extra mm of clearance.
paulesko
415
322
If an opinion helps. I wouldn´t worry much about ease of installation because I guess people buying this case and doing custom loops in it are not going to worry much about ease of installation. But you know better than anyone who is the typical customer.
On a side note giving support for bigger rad could give some side benefit on compatibility that you are not aware of right now....
Reactions: BRSxIgnition
futurewau
71
27
Huge demand should lower the price not make it even more ridiculously expensive.
hetvler
204
153
There's a super cheap coolermaster elite 120 on craigslist that i was going to buy as a stand-in case until this thing releases but the poster wont email me back smh.
Anyone here in denver and have a cheap ass case to sell? could be convinced to pay for shipping if you're trying to offload a case. the cheaper the better lol i just want to get rid of my mid tower.
robojim
254
222
When a product's demand is high, it gives you leeway to push the price up. When the price goes up, you increase the supply to meet this demand though. However, the price increase isn't purely because demand is high but rather the previous design wasn't conducive to high volume production. W360 is redesigning to allow this to be produced in greater quantities but that will entail a price increase to accomodate the extra features as well.
