Concept FormD T1 V2.0
nulio
50
38
Since W360 mentioned the Corsair One layout in some posts, I'm curious if the case will also allow two radiators (with no fans) in negative pressure, as an alternative to a 280 radiator with fans.
nulio
50
38
Mentioned as an alternative to other comparable vertical tower cases...
Have fun trying to nitpick my words when there's no confirmation about the case layout and hardware compatibility. And when alternative neither confirms nor denies anything. What was really your goal with your post? ^^'
W360 clearly knows the Corsair One layout and stated in the past he wants to beat its performance and that the P1 will support HWL GTS240 and GTS280 - slim radiators.
The T1 was designed considering a 120 rad and there's people already using 2x 240. The P1 will be bigger. Who's to say he won't have fun trying to make it possible to have two slim 280 there? Can I be curious about that? Pretty pleeeaase...
Cheers mate
Kit
163
75
I agree with boils interpretation, I dont think Waha wouldn't mention two cases with different layouts unless he was talking vertical format
Corsair one in particular is pretty trick and it would be difficult to replicate in a format which was compatible with the custom build market
bynio
70
74
I can't quite remember, was miniDTX support considered a possibility for this case or has it been ruled out?
If I remember correctly it was mentioned Threadripper on miniDTX, but that must have been a joke.
Boil
1,253
1,094
No joke...!
@Wahaha360 wants 64 to 80 cores in his backpack and has made allusions towards the possibility of a future mDTX mobo that is for Threadripper...! He has also confirmed C8I mDTX support for the forthcoming mainstream SFF chassis (H280 / Mesh-Licious), which is the 'cheaper' variant of the P1... So I would say the P1 will also support mDTX mobos; of which, because it is the only one, means the ASUS Crosshair VIII Impact mDTX mobo...
Tazpr
553
429
Did Wahaha360 say anywhere if this case has the same adjustable IO plate?
I feel like I might end up with one of these because my only issue with the T1 is it's not vertical lol I miss my small footprint Velka5
Boil
1,253
1,094
Go to search...
Set it to "This thread"...
In the "By" field you type "Wahaha360" ...
Then you press the search button...
Then you start reading...!
Reactions: arthasdklol
Boil
1,253
1,094
Just trying to help out (without spoonfeeding), saying what I do when I do not want to scan thru 35 pages...
Using the steps I outlined return 4 pages, much more manageable...
Tazpr
553
429
I think the elipsis' came across as agitated so apologies if I misinterpreted XD
bynio
70
74
No joke...!
Yes, that's what I remembered, but there is no Thredripper mDTX.
