    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
Amonchakai
99
36
Hello,
I think this is the thread for the T1 v2 isn’t it?
I put an order for a titanium, sandwich layout type with aluminum mesh panel :)
But unfortunately, there are no PCIE riser available right now. So I was wondering are all PCIE riser compatible? I guess I should find the right length. And how about the mounting holes, it is all the same?
I only have a 8700k, so I would not mind a gen 3 riser, but I am not sure if I can buy any riser.
thanks
ScottSimply
136
235
Hello,
thanks
It is also about the T1 v2, the gen 4 riser should restock at some point soon. But you can also get the same one FormD uses for the T1 v2 SW from i.e. aliexpress: https://aliexpress.com/item/1005004123118421.html, you'd want the 18.5 cm one. The louqe cobalt riser also works https://shop.louqe.com/products/cob...-pci-e-4-0-riser-cable?variant=39276688506949. If neither of those are to your taste, a more generic daual reverse 18.5cm is optimal, but single reverse on the GPU side with a length of 19cm or more can also work fine.
Reactions: Amonchakai
Amonchakai
99
36
Nice, thank you!
I like the blue one, I will get it from AliExpress, thanks! :)
Aluminyum
158
202
A couple of questions:
The r/sffpc spreadsheet mentions the T1 v3; does that mean a new version is in the works? And if so, what changes are expected?
Have the USB-related issues been sorted out? I hear that the Type-C cables used to be problematic.
Reactions: Dawelio
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
2024-01-29: T1 Version 2.5 Released!​
FormD and the T1 project originated as an R&D venture in manufacturing utilizing NCASE resources. The T1 enclosure is now integrated into the NCASE portfolio.
The T1 Sandwich Kit Version 2.5 is a redesigned and refined version of the FormD T1 by NCASE. The changes made to Version 2.5 can be found on the product page.
The Black Color is available today, and shipping starts tomorrow. The other colors will be restocked beginning in March.
https://ncased.com/collections/t1
https://ncased.com/products/user-manuals
