It doesn't really matter the case, an open air GPU will always be better than a blower style GPU, especially for SFF.In the vertical layout, is it recommended to have a non-blower style GPU?
Watch this video for more explanation
That video covers how the different GPU styles can change CPU temps as well if my memory is correct.I'm more concerned about CPU temps than GPU temps...as my current case (dan A4) has limited CPU cooling capabilities and I live in a hot sub tropical climate. Which is why I have a blower style GPU...because with a less powerful open air GPU my cpu temps suffered worse.
Personally, I live in a hot environment as well (my room easily hits 80f in the summer) and my GPU can heat up the CPU by 3 to 5 degrees (because of the hot air from the GPU going through the radiator), but that's when both of them are running full at 100%, so while a blower GPU would help CPU temps, I personally don't think it's worth the trade off in terms of noise and thermals.
Still, I can't wait for a reveal of the current prototype(s) :-) Still tweaking the internals?Too early to tell, I am actively avoiding promises because I don’t want to break them later.
I’m keeping thing vague to manage disappointment and expectations.
@Wahaha360 regarding space for cables in the vertial orientation, it seems the problem might actually be solved with the upcoming RTX 3000 series since they are shorter in size. And actually the card could be even shorter if stripped of its heatsink
So if the GPU with a waterblock does not excede the lenght of the motherboard (170mm), this means both motherboard and GPU could be placed in sandwich style, dimensions not being greater than 170x170 (motherboard) with ports facing directly towards the back instead of top or bottom!
Hey Wahaha360,
I was imagining that the P1 would be a bigger T1 flipped on its face. This way we get access to all of the I/O, the wifi Antennas are easily managed, etc. But then I saw this and it's terrible, you lose all access to the I/O, the "top" isn't vented, you add extrea volume to the case. Wouldn't it be nice to be able to put feet on any of the 4 mesh sides, rubber stickers feet for the face, and a tray for the rear? That way you have 1 case and anyone can have it oriented any way they want.
I highly doubt he will redesign the whole case based on a mockup with can be fake.
You also have to take into account that not everyone will want to watercool their card or buy a new one when what they have works.
Not to mention that the cases are being manufactured as we speak. I would recommend that you find a way to use the space like adding a reservoir/pump combo or a SSD.
Do you really think I am so stupid to the point I would expect Wahaha to redisng a case based on a leak?
I know this already, I am sharing what seems to be a, by now, a very probable design of the next card. There's a lot of "ifs" but certainly worth a consideration since the case is in the design phase.
This could be fixed by bringing a different pannel with support for this type of cards if they eventually come to market with different brackets. We are already seeing the T1 with support for a different panel if you want a waterblock.
I love your negativity.
Let me introduce you to a solution to "the case is already being manufactured": this could be considered on a diferent iteration of the case.
I do apologize, I thought I was in the T1 thread, very long day.
@Wahaha360 will figure it out, he is in a great position to see what's coming and in which direction the industry is going.
The power connectors are supposed to be on a secondary (much smaller) PCB that goes from the base of that "V" and to the end of the GPU...
And that mockup shows no RAM, unless it is implying HBM of some sort...?
