Production FormD-T1 (Sidearmd), CNC + AIO + 9.5L
Brand name will be "FormD", help us pick a website address:
  • Total voters
    413
DrHudacris
265
370
Working with his case is amazing, you can swap/remove/tweak a lot of stuff with all the components in place!
Couldn't agree more! I swapped brackets by just unscrewing them with parts still in place. I can remove a side beam to plug in my CPU power. I even removed the entire front frame so I can screw in fittings/attach tubing and placed it back (do not do this with PSU attached!). It's amazing.
Brude27
294
586
Anyone knows the purpose of these screws and black rubber pads?
The long screws are also good for the riser strut and stand offs. I used one to reach the PSU bracket->mobo stand-off I used for stability, too. (see below pic)
The big thumb screws are what I used for the top and bottom panels, as well as for the GPU bracket.
I look forward to seeing your build! I'm going to swap out my BR v2 over the next couple of days with my L12S and see how it compares, and then onto the custom sleeving!
Goatee
311
516
I have finished my build but my GPU appears to have started pooing out all it’s pixels. I had a pixelated screen now the the GPU won’t display. As I’m using a I9-9900KF trouble shooting is difficult with no iGPU.
Here is the album for your viewing pleasure while I try to fix it.
jrvd007
Out of curiosity, does anybody know how many test shippers have yet to receive their package?
KetchupFTW
Graphic cards support: 312mm long, 2 or 3 Slot GPU (39.2 or 59.2mm from Side Panel to GPU PCB, including 1.6mm GPU PCB)
So what is the point of a 2-slot card if the vast majority of GPUs are wider than 39.2 mm anyway? Almost only ITX-cards will qualify, and you won't even be able to make use of the length this case has to offer then.
DrHudacris
265
370
I think founders editions are within 2 slots as are blowers. Of course there is also water cooling. So many reasons!
fabio
1,058
1,791
There are a lot of 2 slots GPU as well. EVGA has every version in 2 slots as well.
KetchupFTW
But not all 2 slots are made equal. Will the bottom two cards for example fit?
Board Dimensions1) 240mm*118mm*40mm
2) 28 x 14.8 x 4.4 cm
Both two slot cards, but no right?
max31092
Well, 44mm isn't two slot anymore. There are lots of cards with the correct dimensions and you can find them using comparison websites.
Reactions: DrHudacris
KetchupFTW
But 40mm isn't either apparently, since it won't fit this case unfortunately enough. What websites are you reffering to?
bpark919
32
46
@Goatee what rad is that?
Also, for everyone: would a 12 FPI or a 16 FPI rad cool better? What is the trade-off? From what I can see, a 16 FPI rad would cool better but requires higher fan speed?
DrHudacris
265
370
So then you use the 3 slot mode? I'm not sure what your point is in stating there isn't a point to a 2 slot mode. In the case you ARE using an under 39.2mm card, you gain the advantage of increased CPU cooler height. If you have a larger card, you can still use this case as well. Modularity here is an advantage, and it doesn't result in increased volume.
Reactions: fabio
Goatee
311
516
CoolWorld 240 (it’s 24mm thick) from AliExpress
Cronos83
29
24
Yes and no.
Higher FPI need higher static pressure (which usually requires higher fan speed).
It's simply more restrictive but also has more surface (more fins per inch) and therefore the capability to cool better (in case the required static pressure is provided).
If the fans can't provide the required static pressure a 16FPI will not cool better than a 12FPI radiator - it might actually cool worse.
But... 16FPI is still good for slim fans or normal fans with low rpm. 16FPI is still not a really high fin count.
Ps.: In one of my systems a [email protected] all core and a 2080ti, both under full load, are easily being cooled by a 16FPI 360 + 16FPI 240 @ Noctua Redux @ 570 RPM.
teodoro
82
39
@KetchupFTW manufacturers have different measurement precision, as well as points of reference. Your best bet is to look at the manufacturer’s web page for the specific model and look at the pictures. Nearly all of them include a shot squarely on the PCIE brackets/IO ports. If the cooler pokes above the silver bracket, it’s not a two slot. If it’s flush, it is.
now, it’s possible that a card’s back plate is greater than the 6mm clearance the T1 has (does anyone have examples of cards with a backplate too thick to fit in the Dan a4?) but I think it’s pretty unlikely
denys_349
35
second won't fit because of the height of 148mm, but if 44mm thickness includes backplate I believe that such card with smaller height will fit, my msi 1070ti gaming x is 42mm thick but there are still something like 3-4mm between the card and side panel
____________________________________________
regarding the discussion about LT240 tubing earlier in this thread, maybe someone knows exact tubes model which I can use to replace LT240 stock tubing? the best option is 8/11mm diameters so i don't have to replace fittings as well;
or just some good tubes if there are no such 8/11mm model
