    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
Boil
1,253
1,094
My first priority is to train a new manufacturer, and the only way to do that is to make a product.
Exciting...!
- Intel i9-9900X, i9-9900K (no OC), I9-7900X (no OC), 8700K (OCed)
- AMD Ryzen 2700X (no OC)
- 1080Ti / Titan XP / Titan V / RTX Titan (TBD)
A bunch of Intel CPUs...
A bunch of Nvidia GPUs...
One AMD CPU...
Zero AMD GPUs...
Come on, at least list the Radeon VII...!?! ;^p
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Exciting...!
One AMD CPU...
Zero AMD GPUs...
I’m prob getting the Ryzen 3700X or 3800, but it’s not released, doesn’t feel right to list it.
Reactions: zzmadd
Boil
1,253
1,094
One AMD CPU...
Zero AMD GPUs...
I can understand not listing as yet to be announced CPUs, but the AMD Radeon VII GPU has been announced & is to be released (with immediate direct sales from the AMD website) in less than three weeks...
But seeing as the Radeon VII is an axial fan design, not a blower, you might not want all that heat flooding the chassis (hence the TBD on the RTX Titan)...?
zzmadd
136
66
The layout and cooling is for users looking for the smallest case for
It's intended for YouTubers traveling, traveling pros, and students that travel home during university breaks.
This, in my mind is more of a backpack-able product. Mostly due to the width being relatively narrow.
Can the case host some (4) SATA SSDs? Some content creators need SSDs for scratch, cache, video project files and some enjoy SSDs in RAID 0. Wouldn't make sense being so size sensitive and then requiring RAID external boxes to do the work.
PBJ
358
546
Many mITX motherboards have two M.2 RAID capable slots. Not exactly what you’re looking for but at least there’s that.
Since M.2’s are a lot faster than SATA, you could use one as a primary SSD and the other for scratch, cache, etc.
Reactions: zzmadd
gwertheim
938
1,555
That's not enough considering raw footage these days eat up 100's of gigs
PBJ
358
546
May not be enough, but there will be compromises with something of this size. Older projects could be backed up on very fast external storage for example. Not ideal to some but I think 4 SATA SSD’s is probably not feasible.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
It supports 2x 2.5" HDD / SSD.
Unfortunately, there is no space for 4 in this case.
This sandwich layout is sensitive to obstructions to airflow, so not using 2.5" SSD, cable mgmt, AIO tubing mgmt will affect airflow, thus temps.
Reactions: zzmadd
gwertheim
938
1,555
You clearly haven't worked with red 6k+ footage.
Doesn't matter to me, I have no problem carrying around a portable HDD
PBJ
358
546
Exactly, same thing I said. Use portable storage.
Of course, only you know how much storage you actually need.
Boil
1,253
1,094
M.2 NVMe SSDs are available up to 2TB & 2.5" SSDs go up to 7.6TB now (a really expensive Micron unit)...
So for 4000 bucks you could have 19.2TB of solid state storage, assuming you use an ITX motherboard with two M.2 NVMe SSD slots...
Go with a pair of 4TB Samsung 860 EVO 2.5" SSDs to save a few bucks, you still have 12TB of solid state storage for 2400 bucks...
Mirror the M.2 SSDs for your boot/OS/apps RAID array & stripe the 2.5" SSDs for your media RAID array...
Reactions: fabio and chyll2
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
You might want to look into the ASRock X299ITX with dual 10Gbe or Z390/370ITX with Thunderbolt 3.
A thunderbolt external storage / NAS plugged into those 3 motherboard is quite slick - probably cheaper than M.2 + SSD combo.
Reactions: chyll2
madejackson
32
Any Chance your case fits an Accelero Xtreme III or an Raijintek Morpheus II on the GPU?
The Accelero is 54mm in Thickness and the latter is 59mm/69mm (15mm/25mm Fan).
That would be awesome!
Boil
1,253
1,094
If you read thru the thread, you would note that the SideArmD is intended for a maximum of a 3-slot GPU...
Now let us look at the NCASE M1 real quick...
Hmmm, three slots plus about a half slot worth of room below that...
Both the Accelero III (w/25mm thick fans) & the Morpheus II (w/15mm thick fans) fit snugly into the M1, which has an extra 10mm of clearance that the SideArmD does not...
And the designer himself has stated that this chassis would be best with blower style GPUs, of which the Accelero III or the Morpheus II are decidedly not...
Necere
NCASE
3,300
Seems like the Accelero III should fit, at least with the stock fans. You've got three slots worth of space, and it's only when you use 25mm thick fans that it pushes past that.
Reactions: GerryMz and chyll2
gwertheim
938
1,555
Thx but I rarely do that stuff anymore so it's not a big deal for me
PBJ
358
546
What is the estimated weight on this case? I imagine it’s very light, since it’s aluminum.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Noctua L12S fit verified, all 70mm of it (2 GPU Slot mode)
