Sorry If I overlooked the answer, but, is there a way to add I/O later on, if I order the Black first release one in January?@Wahaha360 if black is main priority is there still an option to add I/O later as that is my main priority over colour.
doesn't look like the slots are present in the new pictures but you can't really see the left side. i'm gonna guess you'd need a new front panel to do so.Sorry If I overlooked the answer, but, is there a way to add I/O later on, if I order the Black first release one in January?
Last we heard the front panel part with the I/O will be available separately for purchase sometime 2020.doesn't look like the slots are present in the new pictures but you can't really see the left side. i'm gonna guess you'd need a new front panel to do so.
Gpu In 3slot mode is 59.2mm which may or may not be enough for a Morpheus 2 cooler.Now that v1 is officially finalized, what are the clearances for CPU Cooler and GPU?
Between having to remove the coil on tube and mounting problem, this is why I don’t want to launch with LT240, these things must be adjusted or I don’t want to tell people to get the LT240.
what would you recommend to cool the i9 9900k no oc if you’re not ready to recommend the LT240? Just so that I can start preparing parts for the T1?
If we are getting a few answers now, a few questions from myself.
1. Do we use sidearmd.com or SFFLAB as cannot see T1 on SFFLAB yet but guess that May change when everything is official.
2.if the LT240 is no longer ideal due to connections etc, does this problem remain when using the LT120.
3. When reading about the M1 it seems the I/O on that requires certain features on the motherboard with many not compatible. Any news on the I/O for the T1 and any similar compatibility issues as this may mean those h9lding out for the I/O version may just go for the one without.
4. Again maybe to soon but would a updated timeline be available so we no current plans for black release, two tone, panels, upgraded parts etc so based on this we can choose black ASAP, hold on for a future variant with different colour, panel, I/O etc or if the former what might be purchased later to make the black version better for individual requirements.
Thanks in advance.
Matt
Thanks.
Think I will go for black then.
Hope I/O is still on the cards for the future and replacement front panel will also be available. I mainly want it for the SD card reader for photography but USB C would also be nice if Motherboards provide the header in future.
Seems to be more Z390 boards offering it than X570 which seems odd due to the age......
As a photographer myself, I'd rather use the port on the back because there is less interference from the cable and its a direct connection to the mobo and I shoot tethered most of the time anyways.
Work with what you have I always say
Any card readers that are recommended? Sorry for the Off Topic comment but will help those who wanted I/O mainly for that.
You as well!Hope you all have a nice Christmas Eve. Merry Christmas and Happy Holidays to everyone.
The build shown is my intimation of a future Sidearm build but in a Louqe Ghost and a large top hat located on the bottom of the case. I took a couple photos of the how I used the SecuFirm mount. I got my inspiration for this approach from @Wahaha360 and his testing with all the coolers. He mentioned the Secufirm was used. I used the included bracket with Alphacool LT240 that slides onto the pump block, allowing you to mount the cooler (I hate this btw). I used the black Secufirm bracket with the built in screws and the black Noctua spacers and then slightly screwed on each end till all the screws we’re able to grab the thread of the Secufirm bracket. I added a photo of a Secufirm kit from amazon to give people a good idea of what’s included and what was used. Let me know if there are any questions and even suggestions. I am still learning and I love to learn new tips about all things computers!
LT240 use 11/8mm for tubing according to their website, and you can also change the fittings if you want to install other tubingWhat tubing did you get for the LT240 because I am struggling with stock tubes in louqe ghost s1. I was trying to run it with a slim rad and one 25mm fan below psu intake like a dan case. I will probably need an extension or custom tubing because it doesn't fit literally needs 1 inch more tubing and it would have worked. I am also trying to make the cooler work with my noctua L12s mounting kit. So i don't have to remote my gpu to do all of this.
