I think the silver version with that black mesh would look incredible also. This is a great looking case. Pics don't always tell the full story and this goes both ways for the good and the bad.
The compatible model is the Eisbaer LT240. The one on the URL above is the larger model and will not fit.Not sure if this is the correct model but I found an American source for the elusive AIO
Search results for: 'catalog product view id 26214 s alphacool eisbaer aio cpu cooler with 240mm radiator 0315ac010201on'
TITAN RIG specializes in quality PC water cooling parts and accessories. Shop top brands like Alphacool, EKWB, Watercool, and more with a 90-day return policy.www.titanrig.com
That one! Hopefully comes back in stock soon.You mean this one
Alphacool Eisbaer LT AIO CPU Cooler, 240mm Radiator, Black
Alphacool Eisbaer LT provides a powerful compact water cooling experienceCan be extended with the Eisbaer-Ready quick-release fastenerIncludes a new slim 25mm radiatorOptimum cooling is guaranteed with the radiator being made entirely of copperConnections are also based on standard G1 / 4 "threadswww.titanrig.com
Please recommend me a case that can support 320mm graphics card that has tempered glass or acrylic side panels.
Still in the factory now~@Wahaha360 @3feetcat Any chance you can share how the re-anodizing is going?
Sounds good. Thanks!Still in the factory now~
will share asap
That will not fit with 2 fans. The only 240mm AIO that is known to fit with 2 fans (one 25mm thick one 15mm thick) is the Alphacool Eisbaer LT240. The reason for this is because the radiator is 25mm thick, allowing for just enough space to allow a 15mm fan to for under the motherboard.I am going to purchase 240mm aio radiator. Which one is recommended? Will something like NZXT X52 (30mm thickness) support 2 fans? I don't mind one being slim but 2 fans are must for me.
The only compatible one is Alphacool's LT240. Please read the post. This question has ben asked and answered countless times.I am going to purchase 240mm aio radiator. Which one is recommended? Will something like NZXT X52 (30mm thickness) support 2 fans? I don't mind one being slim but 2 fans are must for me.
Thanks for your reply. How about something like Corsair h100i (27mm)? I don't like Alphacool's disconnect feature which might cause leaks. Is there any other recommendation that can accommodate 2 fans?That will not fit with 2 fans. The only 240mm AIO that is known to fit with 2 fans (one 25mm thick one 15mm thick) is the Alphacool Eisbaer LT240. The reason for this is because the radiator is 25mm thick, allowing for just enough space to allow a 15mm fan to for under the motherboard.
you can always change the tubes on the alphacool to regular ones if you don't like the disconnects.Thanks for your reply. How about something like Corsair h100i (27mm)? I don't like Alphacool's disconnect feature which might cause leaks. Is there any other recommendation that can accommodate 2 fans?
@Wahaha360
you should just remove the 240mm AIO compatibility in the spec
