    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
aeries
Made an account on SFF.N just to comment on this thread. I've seen the images and I've been sold since forever - I'm also coming out of a Caselabs TH10A so it's from one extreme to the other. Looking forward to watercooling this and hopefully actually getting stock - I have 2x 3090 Strix OCs sitting around and one is destined for the V1.5 when it comes out.
I'll be following closely for updates :)
SFF Watercooled
399
172
How does a GPU in front of the CPU affect thermals when using an air cooler? (Although you're probably not going to be using an air cooler when buying this cases) For example, if you run a C7 with a 3 slot GPU, that will probably choke the CPU so much...
Edit: Whoops nvm
DrHudacris
918
1,720
USA
Can you explain what you mean? It is sandwich style, so both GPU and CPU air cooler should both have access to fresh air through the side panels.
SFF Watercooled
399
172
Edit: Whoops I'm dumb, they do both have access to fresh air. I looked at the pictures wrong.
I know that this won't be possible since version 1.5 is almost released, but I think it would be worth it to subtract 5mm from the width of the case so that only 3 slot GPUs are supported but add 10mm to the height so that 3 standard fans can be used. That way, the sub 10L volume is kept while only losing compatibility for only a few GPUs (mostly chinese ones).
Reactions: joressal
Mao_Setzer
37
71
France
i will have a look at it.
Seems a little pointless to me because results will also be different everytime because of temps?
I've ran timespy twice for example and it will not give me consistent scores because of heat build up.
But so far I've tested the Linkup riser that is installed right now in pcie 4.0 mode and will compare those results to the ADT riser also in 4.0 mode.
Will that work for you?
Hi, did you receive your new ADT Link PCIe 4.0 riser cable that you ordered on Aliexpress ?
No issue, been recognized as intended ? Could compare with the Linkup version ?
PKAWA
490
488
For me it was similar to the linkup but another user here reported that it did not work in his case in pcie 4.0 mode.
Don't know, I had no problems what so ever with it.
I do have a white 18cm linkup I could sell if you need a riser still.
SoSquidTaste
138
214
Speaking of dual rad in V1.5, has anyone here any experience comparing against performance of dual slim 240 rads like TX240 vs. one slim 280 rad like the 280 GTS?
I've seen plenty of Meshlicious builds where the single 280 keeps fat combined TDPs under control, but what about 2xTX240s? Any links I've missed would be mucho welcome too
Wahaha360
a.k.a W360
2,131
10,697
USA
What GPU and Mobo are you using with the ADT PCIe 4.0?
Can you share a photo of the riser you received? There should be a *version number on the PCB itself.
Reactions: DrHudacris
Wahaha360
a.k.a W360
2,131
10,697
USA
Dual XSPC TX240 > GTS 280.
*Dual 240 has about 50% more cooling surface, all else equal, so better performance is expected.
T1 is also much smaller in size, which mean the distance needed to move hot air out of the case is shorter, so all else equal, smaller cases should cool better.
