    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
thelaughingman
1,410
1,564
Curious, what motherboard are you moving to?
X570 Mini-DTX or even bigger form factor?
I'm on the @Boil 's boat with the Crosshair VIII Impact, just gonna max-out on AM4 with 5950X down the line when stock & pricing situation calm down. Personally anything larger is just unnecessary since I just have a graphic card for gaming and no other expansion card. So for now I'm using the NR200 as a temp whilst waiting for Dan-C4 (maybe T1 EVO 😉 ) to shake out.
And before anybody says M1 - no I don't like the visual design of the M1, especially the front. And the case, despite being revised to v6.1 now, is still rather dated.
Reactions: Boil
Wahaha360
a.k.a W360
2,131
10,697
USA
That’s what I thought. Mini-DTX.
The first rule about fight club is you don't talk about fight club.
So let’s see.
Boil
1,263
1,100
Grand Junction, CO, USA
So let’s see.
I am hoping to see this chassis (T1 EVO) work with the Impact mDTX mobo, and its too tall daughtercard (but without any concessions such as mismatched fans or 240 AIO only)...!?!
PKAWA
490
488
Just curious, but what would be the advantage of a dtx board over say a x570-i itx board?
Only thing that's obvious to me is the second pcie slot.
haydenhinson
So let’s see.
Hey,
Slightly off-topic but would you be willing to let me know how you specified the titanium anodizing colour to your manufacturer? as in what colour codes etc.
I'm building a product myself and love the finish you have on the Titanium T1.
Thanks
PKAWA
490
488
So I wanted to let you all know that I have taken a gamble and bought a 18cm dual reverse linkup pcie4.0 riser.
I have just installed it in my case, and there is literally no play left whatsoever. But IT FITS!
I'm not confident to recommend it because it fits so well that I feel another cable from the factory that is just 1mm shorter will not fit.
My fans are under the rad, and are turning freely so all is good!!
DrHudacris
918
1,720
USA
That's awesome! Do you have any pictures? Especially of the fan clearance, because with the riser I got, it had a red plastic cap that intruded into the fan/rad space.
Edit: wanted to add, I got the 20cm version, but not sure if the "cap" is present in yours too.
PKAWA
490
488
I have the caps on there but I have the white one so I'm not sure if the dimensions of the white one are different. I haven't taken pics yet. Literally just installed it, but I will add some later.
max31092
76
45
33
Germany
My 20cm didn't inturude the fan space, but it seems it's a bit of a gamble (Got aGigabyte B550 not interfering when some people said it woud). Nevertheless the white Linkup looks nicer then my black one. I don't like the red cap after all, but well you can barely see it from the outside.
x111
114
45
I have tried 3 different pci4 Linkup riser and all of them have way too long cables on the gpu side.
so I ended up using stock pci3 riser, even though it was hart to stretch it.
maybe with a smaller waterblock those Linkup riser will work.
bobgr8
I came across the news that the corsair sf-series power supplies were failing en masse.
Has anyone come across?
I think I saw your reddit post, and told my new SF-750 (new batch after the recall batch) failed within 2 days of moderate use. Basically couple hours of gaming.
It’s getting RMA’d and corsair said they’ll replace it. Eta is Monday
x111
114
45
in the past there was another recall,
it's quiet frustrating to see that corsair have some quality control issues !!
those Chinese factories need to be under very close control if you want to have quality.
after replacement, my sf750 works well.
it actually worked fine before but corsair said it needs to be replaced.
Reactions: DrHudacris
PKAWA
490
488
My shark fin antenna is working very poorly with bluetooth, so I'm looking at other options. Since the dbi value can't be found anywhere I was wondering if anybody has aftermarket antenna's in use that are noticeably better?
MaZo
71
67
I believe none of the ones I looked at support WiFi 6, so you might want to hold off.
AP2
291
325
Received my HJ radiators over the weekend and pressure tested them and they both check out good. Installed them and pressure tested the full loop - all good. Filled it up and there’s a small leak near the endtank :( Though looking good, they don’t have the cooling capacity as the xspc.
