    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
M1ghtyMau5
So excited about the positive news! What about two-tone orders? Will you be reaching out to us as well to change color or will it still be produced?
Wahaha360
a.k.a W360
2,131
10,697
USA
@Wahaha360
First of all, thanks for the open communication with users in the forum.
I wonder that if its still possible to get left or remaining 25% of white batch? If not, what is the next step to apply for color changing and expected shipping date for the updated order?
Will be shipped to customers who ordered E-White first as a first come first serve basis.
I will make a new powder coated or painted white for T1 V2.0, hopefully with better yields.
AndreasBoegh
I have recieved a shipping confirmation and an actual shipping number from DHL Express for my black T1 (Dec. 1-4th) yesterday. However when checking on the DHL website I get an error message ('Sorry, your tracking attempt was not successful. Please check your tracking number.') and my confirmation window looks as following. So is my order already shipped or did I get the tracking number prematurely?
Got the same thing as you. Error when tracking the number on DHL however I got something on TNT so you could try that. Beware that they reuse the tracking numbers so if it's not showing your package try waiting a little bit.
Paul_the_Octopus
40
28
Great news going forward ! Glad you guys were quick to resolve this issue.
However, What about the december 1-4th batch (50%) being held hostage? Why is no one asking about that ? Since you guys changed manufacturer, what will happen to this batch? (Including mine, which is gunmetal)
Fantattitude
Cupertino, CA
fantattitude.me
Can I haz the Titanium case plz? It looks dope :D
@Wahaha360 More seriously, are you only offering these new cases variants for people who ordered and are waiting for their case or are you planning to put up new customers orders soon? I didn't have the chance to order one because I made my decision for a T1 at the end of november and the orders were already stopped (from what I understood).
S2q
I have same situation. Is it nine digit tracking code? DHL say it uses ten digits for Express. Waiting gunmetal.
baldersz
Yeah support said that TNT tracking number will update at some point. Really happy I was able to secure the gun metal grey!
cpt.bubbles
South Korea / Lancashire UK
Has anyone used PSU extension cords shaped like this in their T1?
I'm looking into getting one because currently the stock cord is too long for the flipped PSU orientation.
It's pushing on the GPU which I don't prefer.
Wondering what length I should go with for a replacement cord.
buttsupreme
does this mean, Nov 2-6 batch of e-white will get it or does the Dec 1-4 batch will still be on the priority?
einmannbude
25
Sorry, if this has been asked before, but I have a RTX 3080 with 320mm on the way and also a T1 on the way. The specs tell me, that the GPU length supported is 315mm, which would mean, the GPU would not fit. On the other side, I have seen Optimum Tech fitting a 3090 FE into the case, which is 313mm in length, but he still had room to route the power cables between it and the panels.
So, do I have to look for another case or is there a chance, that it could fit if I build the case around the GPU as Optimum Tech did? Does anyone have the Gigabyte Vision OC GPU or some other 320mm length card?
Thanks in advance.
PKAWA
490
488
I have four laying around here. two aluminum and two plastic ones. you can have the plastic ones for free, but be aware that the cables are too thin to reliably pull 750 watt so you'd need to replace them anyway.
I'm doing this and also bought some of these https://nl.aliexpress.com/item/4000295910033.html?spm=a2g0s.9042311.0.0.69ad4c4d3h6ZoN
I've decided on this because I have a radiator with a fillport in the back connected to the case which doesn't allow room for the stock cable, and will run the psu flipped with copper hardtubes. Space above the psu is tight.
PKAWA
490
488
Thanks in advance.
It might fit with the newly designed front that is prob going to place the center beam differently.
The room is there, but don't think it fits with the current case.
Reactions: DrHudacris
cpt.bubbles
Thanks, do you know what length the cables should be for the flipped orientation?
I'll probably try them out first then worry about cable gauges. I'm not close to using up to 750 watts with my setup anyways.
PKAWA
490
488
With flipped psu so power cable on top I'm using 35cm which are a little to long.
30 should work but there won't be enough cable to route them any other way then straight to the back so routing them out of sight won't be an option.
I'm happy to send them to you if you can use them you'd only have to pay transport.
