When I see the small difference between the 3080 and 3090 I personally don't really see the added value to wait for the ti over the normal 3080.
there's only 2mm gap between the shroud and the core of the TX240, if you sand down the A12x25 enough to close the lid, the fan blade would hit the core and not spinning. Best is to use the Hanjiang 17mm thick rad or wait for @Wahaha360 to get around to do a custom 17mm thick high FPI radHey guys, Is the only way to fit 2x 25mm fans on top of the TX240 and have the lid close is to sand them down?
@Wahaha360 Does this mean that cases for the december batch will be send with a reworked T frame?
You could flip the PSU and that would help with cables on the CPU side, but I would get custom cables from pslate for the GPU. And if you end up going that route, tell him you want some shorter PCIe connectors for the GPU, he will cut them down and that will give you more room to work with. You can also probably lower the riser a tad to get some extra room.![]()
Having issues with the EVGA RTX 3080 FTW3 Ultra and the SF750 stock cables. First the stock cables are too long. This is causing issues on both sides of the case. Also cannot get the bottom panel over the GPU side because the power cables stick out too much and cannot be bent or moved any more.
Any ideas? Shorter cables will help on the CPU side but the GPU will need a 90-angled connector or something...
Shorter connectors are the main thing that will help. People have fit this card in this case before, and with unmodified cables IIRC, so you should be fine.Thanks for the advice. I will start with the cables. Do you think they will fit with the shorter connectors or will I need to do more?
Biggest problem with the SF750 pcie cables is that they are 8 to dual 6+2 connections. So you have all this extra bulk you dont want.![]()
@ponster can you take a picture of the fans now please (would be great if you could take some measurements to go with them)? So you took out 2.4mm on both fans? I didn't think the blade is recessed that much against the frame, especially given that 2mm off the A12x15 frame and the blade now protrudes out of the frame already.
very interesting! so was the 2.4mm entirely on the intake side or that includes the exhaust side as well? the way I did it was with a CNC machine, don't think I would risk it on the exhaust side since it may affect structural integrity and the knife blade may hit the hub/motor inadvertently. glad it works out for you!Here are some pictures. Sorry, I do not own a digital caliper, but yes, around 2.4mm was sanded. The blades on these fans are slightly lower than the core of the fan, so once you hit the core, you should stop. I also sanded a little bit off on the exhaust side. I took off the sticker, start sanding until I hit the metal bearing. Make sure to tuck in the wires or shield them off.
