    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
I wonder if the QC issues from the latest batch have anything to do with the move to increase production and availability a few months ago. The timing of the reports of these troubled cases and their delivery dates seem to line up with the time there was a massive increase in availability (e.g. being able to place orders on the Monday instead of running out within 2 minutes of order opening on the Friday)
I don't really like speculating but it lines up too well
You are correct.
We open order:
1) so people don't have to panic buy
2) stop scalpers with availability
3) have enough data to negotiate better deal with factory
It may have back fired ?
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Finally some good news, 5950X and ROG3090 for next T1 revision, I could really use a break from manufacturing, so I guess I build.
BRSxIgnition
373
525
Do we know what the next revision will entail just yet?
I may just cancel and reorder once the QC issues are ironed out + next revision is available, if those two things look like they'll happen close together.
Thank you Wahaha360, for all of your responses on the matter by the way.
Reactions: DrHudacris
hetvler
204
153
also what changes are we going to see? I’m in the Christmas batch and miiiiight be able to talk myself into waiting.
PKAWA
490
488
I'm not waiting, the case has most likely not even been produced yet, and the issues are known and being worked at. I'll take my chances
biopunk
245
355
First water blocks for RX 6800 (XT) and RX 6900 XT released.
Bykski RX 6900 XT WB: 262.7x135.71x23 mm
Bykski RX 6800 XT WB: 240.3x127.48x21.73 mm
Backplates are slightly longer.
Looks like in case of 6900 XT a DDC pump will definitely fit without a heatsink, but even the shortest heatsink at 26.1mm will require some sanding.
In case of 6800 XT, a DDC pump will fit with a heatsink, even with the top facing the side panel.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
SO, Officially there will be a NEXT Revision! ?
When is your 5950X and ROG 3090 build coming?
I can prob get the 3090 between 2.5-2.75 GPU Slot spacing, leaving 55-60mm to CPU cooler.
Then maybe I can modify the Noctua L12S or C14S Air cooler to fit with the 5950X with VLP 64 GB Micron 3200 RAM.
A little bit of under-volting will be required, maybe an all air cooled build in the T1.
flar
78
46
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
2020-11-10: Defective Batch, Cancel, Ship Later or B-Grade?
We are officially stopping all T1 November shipments due to Quality Control concerns. Our core team have arrived at the factory and are trying to fix the problem in time for December shipping.
As some of you may or may not know, there are quality issues with T1s shipped in October. As far as we know, there is almost 10% defect within the October shipment, which is much higher than the 2% expected for low volume products. The production problem was concealed from us, and repeated so by bad actors within the factory. However, it is our oversight, so we will take the responsibility.
Our core team arrived at the factory this afternoon, and spent the last 5 hours investigating the cause and stopping packages from being shipped. It is now 3AM in the morning in Asia and we are notifying you now because we found the cause of the problem. For next steps, we have emailed those affected with some options.
Please accept our apologies for this unfortunate situation. Let us know what you want to do via support@formdworks.com and we will try our best to take action this week.
Luke NK
126
116
Hello Wahaha,
What do you mean by this? C14S is 115mm height
Do the changes you plan to make with the L12S involve fixing the cooler interfering with the side strut of the case?
taquito
25
Thanks for the open communication @Wahaha360 . Disappointed I won't get my e-white for Xmas, but there are worse things. I'm very happy to see you take responsibility and do what needs to be done. My faith in you and your team has always been strong and I'm glad it's not put to shame.
Best of luck resolving the situation.
T_Dawg
Out of curiosity, is this expected to delay late orders with estimated ship dates of late December? Understand if that’s the case, but want to adjust my plans and expectations accordingly.
Reactions: BRSxIgnition
DrLeroy
Noob Saibot
May 15, 2020
186
117
Much appreciation W360.
BSartist
48
38
Without knowing what kind of defects were included in "B-grade", I opted to ship later. I've waited long enough, what's another month? ?
I would have been OK with anything except inability to assemble and cosmetic defects to exterior surfaces.
Reactions: FischOderAal
zyv
That would also be my question, since I ordered one for that december shipment too. Yet, I still want to confirm: I'd 100% rather have a delayed shipment than a defective case.
