    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
JDK
96
93
To those of you with a Corsair Hydro Series H100i RGB:
Which motherboard and RAM do you use and are there any concerns regarding routing?
Would love to get Crucial Ballistix instead of Corsair Vengeance LPX, if possible.
Navic
587
1,341
Crucial Ballistix isn't much taller than LPX, you should have no problems no matter the motherboard.
But to answer the first part of your question: my build uses the Asus B450-i and Corsair LPX
Reactions: DrHudacris and JDK
Kapsi
50
72
Hi, first of all I want to apologize if I bother you people with this.
Earlier this year I bought supplies to make custom cables and sell them to the Formd T1 community to get my own case, but the shipping prices skyrocket due covid and I didn't find the selling price to skyrocket any more, so I decided to wait for better times. Anyway, right now I find myself wanting to create a cable set for my non-existent build and I wanted to ask for help with the cable lengths. If everything goes well, I would like to have a build similar to the one in the picture below, so if any of you have a build similar to this one with custom cables, I would appreciate very much your help with the measurements. Thanks in advance and here is the picture.
Reactions: eedev
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
I have the same problem with my riser as described here:
Is this a problem with my batch or was it always like this?
How did you folks deal with this?
Remove the black tape on the PCIe Riser, it will make the cable bend easier, and that should solve the problem.
Reactions: fabio and Navic
Tutorial
random question. does anyone know who posted the builds with the ddc in front of the mobo in 2-slot mode (and if the people who own these builds are reading this can you send me the pictures)? I remember specifically seeing two different builds and, since I had a different plan in my mind, never bookmarked them for later. I have my case and everything, just planning my loop and wanted some more reference shots.
Navic
587
1,341
Here's a comment on reddit that mentions the length the OP ordered for their custom cables. Standard orientation PSU (not flipped), because when you get custom length cables, you don't really need to flip the PSU.
Revolution
26
I have the same problem if i forced to close gets dc so no top panel for my now because of this
hetvler
204
153
Sanity check please! Ordering some custom cables, want to make sure i'm getting the right ones.
1 24pin - https://www.pslatecustoms.com/colle...formd-t1-24-pin-paracord-custom-sleeved-cable
1 8 (4+4) pin CPU - https://www.pslatecustoms.com/colle...4-4-pin-cpu-eps-paracord-custom-sleeved-cable
however many 8 (6+2) pin cables my card needs - https://www.pslatecustoms.com/colle...-8-6-2-pin-pcie-paracord-custom-sleeved-cable
I'm using an m.2 drive so I DON'T need a sata cable right - https://www.pslatecustoms.com/colle...d-t1-sata-power-paracord-custom-sleeved-cable
Also, what is a sense wire? Do I need/want it on my 24pin?
This should be all the cables i need right?
Navic
587
1,341
Corsair H100X will fit?
Curious about this as well, as I really don't care about any lighting. I expect to need to swap to 15mm tall fans though.
Yes, it will fit. But, it will have lighting, super bright white lighting you can't turn off. You're also losing out on other features, like controlling the fans based on the liquid temp instead of CPU temp. Furthermore, you won't be able to control the pump speed, it will just run at 100% all the time.
Instead of getting the H100X, get the EK 240 DRGB (you can control the pump speed, but no liquid temp fan control) or other H100i models.
Navic
587
1,341
You are getting the correct ones, but consider getting the unsleeved ones, as they don't take up as much space as the sleeved ones, they bend easier, and are also cheaper. So unless you want the custom colored sleeved cables, get the unsleeved ones.
If you don't have any drives or pumps that use SATA for power, then you don't need a SATA cable.
You want (and probably need) sense wires. He explains what they are in his FAQ.
hetvler
204
153
Yeah i realized after the post that i don't care at all about sleeved haha. I'll get the unsleeved ones.
I'm not custom looping (read: im a coward) so any AIO I get should already have the proper cable installed and I won't need to buy a new one, correct?
Gotcha, I'll read up. Thanks!
