    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
PKAWA
490
488
Those are the tygon R6010, with an additional 30cm spring around them because they will bend without them.
Tazpr
552
426
Australia
Anyone with a ROG Strix 3080 or 3090 in T1?
I wanted to try it but it's A LOT of money in the event it doesn't fit... from going over the dimentions I think the card will hit the front panel as it's very blocky.
It's also very tall so if it does fit I feel strongly that it will be basically contacting on all sides - do you have reason to believe it will fit?
DrLeroy
Noob Saibot
May 15, 2020
186
117
So my Finances have found a bit of a wall recently with home renovations going on and this Covid dealio. . .So my plans for a custom loop are falling away fast, as the Mr's has put a stop to any plans for ordering a 3080 or 3090.. .. and without that, i see no point in completing a custom loop, so will probably sell my TX240 and Eisbloc LT Solo. and head for a 240mm AIO for my 3950x instead.
I am torn between the options though and am leaning towards the EK240 AIO option, though seems from non SFF related forums it is a less than ideal performer for anAIO.
whats the opinion of those here of the thermal performance of the EK240 AIO in the T1? static temperatures aside, looking for more an opinion as if it is indeed a 'good' option or if something like the corsair options perform better?
thelaughingman
1,410
1,564
I'm using the EK with 3900X, PBO enabled, Clock +200MHz offset, Vcore -0.05V offset and temps are 45-50C idle, 73-75C on spike as clock boosts, sustained full load at 80-83C, with ambient temp of 28-30C. That's good enough to me, nothing to complain about really.
Did not get to try the LT240 or other Asetek-based AIOs so can't compare them directly.
Reactions: DrLeroy
Wahaha360
a.k.a W360
2,131
10,697
USA
My Strix 3080 stuck in customs.
I think it should fit, but I guess we wait.
Tazpr
552
426
Australia
That's such a pain! You're really having a great time lately by the sound of it XD
I mean if you think it should then that's enough for me XD it's by far my favorite of the current cards out and the one I wanted to go for and it looks like it should fit but extremely snuggly.
I'm all but decided on picking up a 3080 Strix, although I know I'll be waiting a long time haha
Tazpr
552
426
Australia
@Wahaha360 My 318mm long Zotac Trinity 3080 barely fits in terms of length and my 140mm MSI 1080 barely fits in terms of width, so hopefully the 318.5 x 140.1 Strix will fit. [Zotac photos] [MSI photos]
You might need 180-degree PCI-E adapters to deal with the width of thee Strix and some PCI-E bracket modding to deal with the length
At least the strix has recessed plugs - the length is the part in concerned about because it looks like the zotac pokes into the front panel recess which the strix can't.
Reactions: Navic
PKAWA
490
488
I've placed the second M.2 ssd behind the radiator with a 30cm extension cable.
Added a fan to the heatsink for the chipset and first M.2
Now just waiting for the black Noctua fans to hit the market so that I can take it apart again hahah.
If you look closely you could probably just see in the left top corner that I've used a screw to secure the gpu to the bracket of the psu.
That way it stops it from sagging forward and staying flush with the middle.
