Well, the SPC is 35mm, so even thinner...
But the Alphacool Plexi top has all side ports you need. ?
I did manage to put the dual DC-LT next to the top TX240, well, with power cord and power button relocated to elsewhere.
Ahahahah, if you know me, I don’t need ports, I will find them anyway ??But the Alphacool Plexi top has all side ports you need. ?
It’s weird. Because mine fit.
EK SE Classic or XSPC TX240
Sorry in advance (i know its repeated a lot) But out of these two radiator which is the best when considering fitment, thermals and noise
EK SE Classic : I understand that the EK SE classic is the exact clearance above mobo so their could be fitment issue, in practice has anyone actually had any issues with this
XSPC TX240 : Higher FPI so potentially requires higher speed on fans and slightly wider so potential fitment issues, again, has anyone actually had any actually had any issues getting it into the case and is the higher FPI actually an issue?
Hi @fabio which card do you plan to buy? Seems like FE card is different from the reference card so I think we need to find a 3rd party GPU with the reference PCB.BTW, The Reference Card RTX3080/90 Blocks from EKWB, with the RGB shit, are ONLY 230mm long! This means we will have a LOT of space to play for other stuff!!
Depending on the components you choose, you can cool everything with a single 240mm rad, and you would get better thermals (especially for the GPU) and noise levels compared to a 240 rad and a 3 slot GPU. Also, I think some people go over the top just because they can (Dr. Hudacris for example)Serious question: why are you people custom looping your CPU and GPU into the same 240rad?
Don't take this as calling you guys dumb or anything i absolutely admire your dedication and skill - I've never custom looped so i'm definitely intimidated to try it, but in my extremely inexperienced and probably smooth brained view wouldn't 240 rad in 3slot mode with the biggest card you can fit lead to better thermals and temps? more radiator and fans = more better right?
What am i missing here? educate me.
I know huda has like 2 2080s in SLI or some shit so I get it in that use case but other than that, am I wrong?
I think you are talking about the 240AIO + 3-slot GPU configuration.Serious question: why are you people custom looping your CPU and GPU into the same 240rad?
Hi @laplamgorThank you.
I finally installed the fansssss.
Cable management is a disaster. It is definitely not as clean as fabio's tx120 ( ? ).
Ran a quick test and got 3~4C improvement @30% PWM (~3k RPM, which has similar noise level of full speed a12x15)
Will have more tests when I have time.
The other side is still good.
I just use double sided taps on the top and bottom.Hi @laplamgor
I've seen your build from reddit and just found that your are here!
I have a question about your custom transparent side panel. I'm curious about how it is mounted onto the case. I'm also planning to order a side panel, for both good looking and blocking air from passing through the CPU side (Yes I want this side to be sealed). So does your panel seal the CPU side well?
Well I think that's enough and I'm considering ordering an acrylic board. I think that fits well. Thank you!I just use double sided taps on the top and bottom.
It is sealed for 3 edges only. The back panel of the case is not touching the TG panel. There is a small gap for the thickness of the oem mesh panel.
Is there an expected release date for the glass panel?
For my build, I do need the CPU side to be not ventilated lol. If that panel was not released when I start building I'll use PVC sheet to seal the CPU side panel first.Right now Q4 or 2021
WHILE IT MIGHT LOOK PRETTY, THERMALS WILL SUFFER
?!?!?!?For my build, I do need the CPU side to be not ventilated lol. If that panel was not released when I start building I'll use PVC sheet to seal the CPU side panel first.
Sounds weird right? haha?!?!?!?
What do you mean you NEED the cpu side to not be ventilated?
Do it!!Sounds weird right? haha
I'm planning a negative pressure build. I'll put a large radiator at the GPU side and cool it using the top fan. That means I must seal the CPU side and the bottom side well so that most air can flow from the GPU side. The only concern is that the mother board may not be cooled sufficiently in this configuration. I'll test it's feasibility and whether I need to provide some air to the motherboard. Maybe I'll not seal all pores and flip the PSU to create an air flow at the CPU side.
If that succeed, this may be the most cool (both visually and physically) build and I can overclock everything in a 9.5L case. That's nice isn't it?
