Is that a challenge?I would avoid the FTW cards for sff, they never fit in the cases properly
considering the size of the heatsinks required to keep these new gen of cards under control I fully expect no factory air cooled card to fit in 2 slot mode, but happy to be proven wrongSo to update everyone who are hunting for a 2-slot compatible 3080 (or 3090,....good luck) for their T1, EVGA moderator on their forums got the GPU width data out finally for the XC3
Thickness of the 3090/3080 XC3 models with backplate (XC3 Ultra/XC3) is 1.78in. - 45.1mm.
Thickness of the 3090/3080 XC3 models without backplate (XC3 Black) is 1.61in. - 40.9mm.
40.9 vs 39.2
Goddamnit..
because SLI is dead man. they don't even put SLI fingers on the 3080 no more ?(don't ask why the 2nd card is only under 60% load, I don't know why).
I'm waiting for Big Navi but will definitely going for something like the Liquid Devil RX6900XT. Not sure about which blocks EVGA uses but the 5700XT Liquid Devil uses EK's block and even being sold on EK's web shop. So quality would not be a concern at all, though you'd better check with EVGA directly on exactly how the Hydro Copper is made and which block is used there. There are 2 things IMO to consider (somebody add more if I miss anything)Anyone consider going with the EVGA Hydro Copper? What are the pros and cons of going with EVGA Hydro vs. aftermarket GPU water blocks from EK or the likes?
EVGA - Articles - EVGA GeForce® RTXᐪᔿ 30 Series
The EVGA GeForce® RTXᐪᔿ 30 Series are the absolute definition of ultimate performance.www.evga.com
I think we have a madness around here that isn't dissuaded by concerns of fitment. I'm gonna stuff that soft curved, red highlighted, RGB brick into my case one way or another.I would avoid the FTW cards for sff, they never fit in the cases properly
Thats not true according to a a few people.All the EK aios bulge in 3 slot mode, but not in 2 slot mode. And if the CM requires molex for just the RGB and not the pump, then I see that as a win!
smallformfactor.net
Well well well, this is very good newsThats not true according to a a few people.
Fits just fine.
Log - My SFF builds / journey
Finally decide to have a dedicated thread to document everything SFF that I do. So here it is. Preface: Just a bit of background about me. Loved video games growing up (even more because my parents forbid it in typical Asian parent fashion), which led to my enthusiasm for computers and...smallformfactor.net
Yeh it is good news.Well well well, this is very good news
Might depend on the MB though, but seems like it fits perfectly with no bulge
I'm not sure if the Asus Strix cards will fit, but I did notice that they have recessed power connectors, so if the shroud can fit in the case, then there shouldn't be a problem with the power connectors making the card too tall to fit.I went through a lot of the specs on the 3090 and 3080 cards, it looks like the MSI Ventus 3X, the EVGA XC3, Asus TUF series, and the Inno3D Gaming X3 should all fit with relative ease. Granted, I'm primarily looking at the 3080 models, but the 3090 models seem to have very similar, if not the same specs for these particular models. Keep in mind the memory modules on the rear of the 3090 pcb may cause issues, but we wont know without someone being crazy enough to try.
EDIT: The FTW3 should also fit, but if you want to be safe before it arrives you could always buy a few of these
The 1080ti FTW fits just fine, and the maker of the case showed off that the 2080ti FTW fits too. You must be thinking of some other card.I understand that but from my experience both the 1080ti FTW and if I'm not mistaken the 2080ti FTW cards were too big for the ghost (2018) and the T1 (2020). I don't want anyone to run into issues where it's 3 mm too tall without taking consideration for the wires and having the lid not fit on the case because the card and the wires are sticking out 6 or so mm
Love your current pump solution, just have the pump block hanging off the side. You say your waiting for the 2600 pump to be back in stock, why dont you just remove the pump out of the lt solo, i belive the cpu pump block also has a 2600 in it. Also alpha cool should be coming out with their 2nd gen dc-lt pumps (the new pumps are in the new aurora aios). Id suggest temporarily using the pump out of the lt solo, and then upgrading to the newer pump later on![]()
PSLATE cable come in.
Can't close case using LT-SOLO as Res+Pump combo.
Waiting on Performance PC's restock DC-Lt2600. They send me DOA.
Have 3 option for 2600.
Primochill RSX hardtube fittings BIG disappointment.
One, I hope for darker Magenta. This more pink than Magenta.
Two, fitting top part that screws into o-ring feel cheap. Feel like cheap plastic, even though website say aluminium. I don't believe.
Exactly my thoughts! I saw a thread once showing exactly the upgrade path from lt240 to EK block + lt2600 + ST25Love your current pump solution, just have the pump block hanging off the side. You say your waiting for the 2600 pump to be back in stock, why dont you just remove the pump out of the lt solo, i belive the cpu pump block also has a 2600 in it. Also alpha cool should be coming out with their 2nd gen dc-lt pumps (the new pumps are in the new aurora aios). Id suggest temporarily using the pump out of the lt solo, and then upgrading to the newer pump later on
Anyone has thoughts ono MSI vs EVGA vs ASUS purely on past performance of the individual board series and overall company track record? Might not be able to wait for reviews with the 3090..
