depends if its hot glue or super glueI'd take the whole back plate off to save your components, and carefully use a heat gun in that area. That should ideally allow you to get that magnet out without too much hassle.
Would that work for super glue? I just added a small dab.
I have acetone but was hesitant about using it on the anodized aluminum. Unless that's nothing to worry about, I'll give it a try.I've never had a little bit of heat fail me when trying to un-stick something, but generally solvent based liquids like acetone or finger nail polish are great for removing super glue as well.
Hey guys, just a warning. Don't buy these magnets. https://www.ebay.com/itm/M00880-MOR...4x3-mm-Neodymium-Disk-Round-Mini/201683745008
They are only 2.75mm in depth and end up coming short of the frame. Didn't realize it'd be an issue until after I glued them in. They are very strong on direct touch, but ended up having practically no grip on the side panels due to the gap. Measure with a caliper first before glueing and don't assume like me!
I bought this exact listing on July 30th, and for me they are recessed like your picture but are still able to hold the side panels in place when the top panel is off.Hey guys, just a warning. Don't buy these magnets. https://www.ebay.com/itm/M00880-MOR...4x3-mm-Neodymium-Disk-Round-Mini/201683745008
They are only 2.75mm in depth and end up coming short of the frame. Didn't realize it'd be an issue until after I glued them in. They are very strong on direct touch, but ended up having practically no grip on the side panels due to the gap. Measure with a caliper first before glueing and don't assume like me!![]()
Ayy, I’m glad they work for you. I have 5 out of 6 out using acetone (last one being a bitch) so at this point I’ll prob order the ones from K&J for good measure. I’d like stronger ones anyway as I have some AIO tubes that need a little squishing in.I bought this exact listing on July 30th, and for me they are recessed like your picture but are still able to hold the side panels in place when the top panel is off.
I'm done! I think...
I'm actually now thinking of a way to get 25mm fans and TX240 together...I failed before but this build gave me some ideas. This is leviathan SF240 (29.6mm) and Kaze flex slim without pads (14.8mm).
Edit: got that last bugger
Damn, mighty impressive power density! What are we going to do with all the extra room?![]()
FE PCB is tiny.
MOAR HEATSINK SURFACE AREADamn, mighty impressive power density! What are we going to do with all the extra room?
