    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
notbitcoin
77
204
Would you mind listing the connections you used in your loop and how many of them? I really like this setup. Sorry for the handholding, I've never custom looped and am not entirely sure what is needed.
it's really not an easy layout to implement if you aren't planning it all out to ensure compatibility. i'll list the fittings off, but know that this works because a) i am in the 3-slot gpu config, b) i'm using a 25mm radiator that allows for me to mount fans between it and the motherboard (creating space for the fittings), and c) i'm using a motherboard with a non-obtrusive heatsink + io cover on the side vrms/no heatsink on the top vrms/8-pin + fan connectors aren't in the way (8-pin is still rough, but obviously it works). if you deviate from this in any way (such as going with the TX radiator, which requires you to mount the fans above it), and it doesn't work out, then that's on you homie.
note that you also don't necessarily have to use these fittings in this exact manner (and you may want to use barrow instead of bitspower, where possible, to save money), i just had a bunch that i didn't want to go to waste, so i wound up working around them-
1 - https://shop.bitspower.com/index.php?route=product/product&product_id=1896
2 - https://shop.bitspower.com/index.php?route=product/product&product_id=1815
3 - https://shop.bitspower.com/index.php?route=product/product&product_id=1921
4 - https://shop.bitspower.com/index.php?route=product/product&product_id=1718
5 - https://shop.bitspower.com/index.php?route=product/product&product_id=1769
6 - https://shop.bitspower.com/index.php?route=product/product&product_id=1891
7 - https://shop.bitspower.com/index.php?route=product/product&product_id=2549
8 - https://shop.bitspower.com/index.php?route=product/product&product_id=1893
9 - https://shop.bitspower.com/index.php?route=product/product&product_id=3956
10 - https://shop.bitspower.com/index.php?route=product/product&product_id=1937
11 - https://shop.bitspower.com/index.php?route=product/product&product_id=1891
12 - https://shop.bitspower.com/index.php?route=product/product&product_id=1815
13 - https://shop.bitspower.com/index.php?route=product/product&product_id=1923
tubing used - https://www.mcmaster.com/5119K88/
and then i have another https://shop.bitspower.com/index.php?route=product/product&product_id=1896 that i use to screw into the t-block to drain/fill with
best of luck if you do decide to try this though.
taquito
25
Quick question: I ordered the XSPC TX240 radiator. It was recommended as one of the best performers. I believe it's also one of the thinnest. What's the best Noctua fan to pair it with ? do I need the slim 15mm ones or can I fit the full 25mm ones ? Just looking for best noise/cooling performance that fits.
kazuma86
276
164
Somehow the notification didn't even reach my spam folder (googlemail). Was there some trick to it?
Luckily I was able to snatch one by coincedence.
I hope Formd.com will open with new stock soon!
(and maybe confirm if "silver" means silver body and silver mesh or silver body and black mesh, since there was some confusion...)
I think some contrast color with black mesh panel give more point plus for T1. Already order for Gunmetal and black mesh panel give more credit for me.
Reactions: Cruella Devill
Ashenfall
57
79
you'll need 2x 15mm thick fans placed between the panel and the rad
Reactions: DrHudacris
AbsoluteRecoil
Hello all, first time posting here.
I am having trouble with fitting my loop. The cables are blocking the pump + res.
I decided to re-orient the PSU, a sf750, into the flipped position.
I am having trouble lining up the standoff with the side screw which screws in from the front face.
What am I missing here?
thanks.
Nero
61
68
Hi guys,
Received my case without any issue :)
Surprisingly, you can fit 3 fans with a H100x (27mm thick) with 0 bulging. The rad doesn't have the squared ends the H100i has meaning it goes all the way to the front. That gives you the room to fit 1 a12x25 below and 2 a12x15 above.
You can also fit a 92mm a9x14 around the m.2/VRM area even in 3 slots mod, you have basically the perfect clearance before the fittings get in the way (This was known to work with custom loops because of the thin block but I don't know if people knew it worked with some AIOs.)
Might make the H100x a great aio choice.
If it interests anyone I can take some photos.
kazuma86
276
164
Hi guys,
You can also fit a 92mm a9x15 around the m.2/VRM area even in 3 slots mod, you have basically the perfect clearance before the fittings get in the way (This was known to work with custom loops because of the thin block but I don't know if people knew it worked with some AIOs.)
Waiting your photos :D
I'm looking another AIO for T1 and will look best option.. Also can you share your specs too?
Reactions: kmnvhs
Nero
61
68
Here you go
Here you go
Right now The 92mm is held by double sided tape as this is just a test fit (hence the missing screws). Will think of something more permanent when the build is finalized.
For the specs same thing this is just a test fit with my current build (R5 3600 + 1080Ti) but the plan is to upgrade to R9 4900 and RTX 3090/6900XT whenever possible.
Also, I'll prob add a vinyl cover on the flipped corsair logo it's triggering me lol
kazuma86
276
164
Here you go
Here you go
Right now The 92mm is held by double sided tape as this is just a test fit. Will think of something more permanent when the build is finalized.
oh, very nice build <3 good cable management :D I'm consider using 3 fans too.. will try to figure out..
Reactions: Nero
nulio
50
38
@gwertheim @Wahaha360 Will the new Instruction Manual have a list of all included screws, IKEA style? To check if none is missing before the assembling.
The components are really well packaged! Nit-picky feedback: the glue between the cardboard and the foam ended up in some of the components, but it's quite easy to remove.
@worldtour sexy looking GIF there! How did you secure the 120 fan over the motherboard?
gwertheim
938
1,555
Yeah
eblvrm
Hi guys,
It looks like you can push right angled end radiator from H100i RGB XT also all the way to the front or I am missing something? Anyway as soon my parts arrive I'm going to try similar 3 fans setup with Cooler Master ML240L v2 AiO
hetvler
204
153
Awesome post, thank you for all this! Its a bit more intense than expected but you basically answered every question I could have moving forward re: fittings and tubing so even if I don't go this route its still great info. Thanks!
zacobin
48
45
So I saw brief mention of it earlier but don't think anyone posted a build with it. Would the EK-XTOP DDC 3.2 be a good pump/top combo for this case? Assuming a reference card for GPU length
