    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
2,740
2,876
Spokane, WA
That undervolt is way too low for a 2080ti IMO. My 2080 Super has an undervolt of 919 mV and I found this to be stable in everything I do, and I can't go any lower. Of course, undervolts are like overclocks, in the way that each card is different, but most of the 20 series undervolts I've seen are usually above 900 mV
I also have a 2080 Super and it is stable at 900 mV, I tired 875 but wasn't stable. I would try that 2080Ti at 900 mV.
vusun123
88
66
Has anyone tried this similar set up with a 240 rad in a custom loop? Will I get better temp than my current set up? I doubt CPU and GPU heat load will soak up the small radiator. (CPU 100 W GPU 260W in game)
This is what I will do next, except my GPU is the EVGA 2080 Super XC Ultra. Btw what is your 10900K undervolt settings, both BIOS and XTU ? I left things on Default and set a -35mV offset and things are looking somewhat OK with my NZXT X53 (Cinebench maxes out at 84C, Blender at 89C) but go any lower then I will start seeing random reboot. The rest of my watercooling components will arrive this Friday so I can start fiddling around soon
kazuma86
276
164
Well, this is my cable management an AIO installation.. Will try to figure out with new sleeve and other strategy, since I'm not a builder like @fabio , will try another custom loop until tax is free also ampere/big nave not more than US$ 800 :v .
This is EKWB with noctua and alphacool fans >_<
Please ignore my desk once again :D
@Wahaha360, i will be waiting P1 so badly..
@Wahaha360 do the 4x3mm side panel magnets need an adhesive?
You can use double tape for adhesive.
payo36
29
38
Thailand
www.minicomputers.net
That is a very sexy GPU!
Custom loop will definitely help. 360 watts isn't too bad for a 240 radiator.
But I've got a question about your undervolt. If the voltage set that low crashes it in sometimes, why not turn the voltage up to 900-950mV? I've never owned a 2080 ti, so what is it's stock voltage? Any reduction will help as long as it's stable.
I've tried 900mV, it's stable but not much reduction in temperature.
AP2
291
325
Anyone know of a pcie 4.0 nvme extension? I would like to relocate the sabrent rocket nvme as it gets pretty hot and the rise cable is right on it.
Thanks!
thelaughingman
1,410
1,564
X570-I Gaming board and Vengeance LPX? how's the pump fitting pushing against the RAM? I couldn't leave mine like that so I had to rotate the block and have the tube coming out of the rear IO side
kazuma86
276
164
Yes, haha.. Asus and Corsair fans >_< want to buy asrock B550 but price going crazy in here.
IDK man, can't answer but there is no problem with that.. I just set under RAM, to be honest need 3 times to configure cable management since cable touch the fans.
Reactions: thelaughingman
iksretep
51
25
Los Angeles
There is so much in this thread, I tried searching ... but oh my ... how is the durability of the T1? does it show scuffs, nicks, fingerprints, etc? Is the finish similar to the M1?
Ok now here comes the blasphemous part - can it be powdercoated, what are the tolerances?
kazuma86
276
164
yeah, I figure B550 boards have much higher margins than X570, no brands in VN have X570 in stock anymore, they're all pushing for B550 now, which sucks big time!
Limited Stock everywhere.. unless trying to keep money until next year.. haha..
Durability?
1. Build quality is great, @Wahaha360 is founder of Ncase M1
2. Fingerprints? Everycase with black color always leave finger print for me >_<
This case like build RC or Lego, depends your hobby :D
Reactions: DrHudacris
iksretep
51
25
Los Angeles
Durability?
Thanks for your answer. I had/have many black cases, and only M1 shows fingerprints on it because of the anodiez finish. I know who makes the case, I was just inquiring about durability. M1 shows a screw mark, and scuffs just when you look at it wrong, and even though I'm super careful there is always something - I've had the V5 and now I have the V6.1 which I have not build in yet. I had no fingerprint "issue" with 3 of the Sliger cases I own because they were powdercoated or at least had a different finish - that's why I was asking if powdercoating was possible and tolerances which would allow/not allow such finish. I'd say building this case is more like IKEA than LEGO, but to each is own ?
thelaughingman
1,410
1,564
IKEA is also right in a sense, LEGO just comes to my mind quicker haha
I have the black variant and it does show fingerprints but you can easily wipe it off with a microfiber cloth, nothing major at all. The tolerance is super tight on all the pieces, I've already scratched up the inner of a lot of the parts. But that was me tinkering with the case for 4-6 hours everyday for the past week. If you just build once and leave it I don't think it will be a problem at all. If you do powder coat on top of the anodization, I guess the area where the pieces meet will scratch all that paint away anyways, due to the tight tolerances mentioned. But for the outer area you should be fine.
Reactions: iksretep
kazuma86
276
164
Yeah, thats why I put another cloth upside my table.. Haha.. even with Ghost, I didnt care so much. I'm agree, build T1 like assembling your IKEA furniture.
Reactions: iksretep
gwertheim
938
1,555
Because of the oils on your skin, fingerprints cannot be avoided on anything you own unless you wear gloves. It's unavoidable
Reactions: iksretep
DrHudacris
918
1,720
USA
Nooooo! Don't powder coat! At least go with something high quality like cerakote.
Another benefit of cerakote over powder coat is it's thinner layer, so should maintain the tolerances better.
Reactions: iksretep
fabio
1,885
4,325
yes, I put some glue on mine
Ease of build is about the same, I've used both boards and sticking with the Strix, whereas @fabio had both in the T1 each for a period of time and now sticks with the Aorus. It's more or less which one has the features that you want more
The Aorus, despite the number of ports, has way better chipset temp! The VRM I cannot say anything, because Asus for some reason has blocked the reading of the temp on this board.
Navic
587
1,341
I had to install the chipset or general MB drivers before I could see my Asus VRM temps. I can't remember exactly how I got them, but I remember I had to install some driver. Maybe it was a BIOS update as well.
