I am thinking about adding a 2.5” drive behind the PSU mounted with double sided tape. Not sure how the heat from the psu will affect the drive the though. I’m not sure I can get a drive behind the front panel with the DC-LT 40 in the way.
I pay attention, but I think the heat will be quite annoying. Is there a gap to put it on the bottom panel?I am thinking about adding a 2.5” drive behind the PSU mounted with double sided tape. Not sure how the heat from the psu will affect the drive the though. I’m not sure I can get a drive behind the front panel with the DC-LT 40 in the way.
Is that rad Copper or Aluminium?i looked into it a a few days ago as well. a couple guys did a deep dive on it in 2010/2011 on chiphell and basically concluded that the performance was underwhelming (even for its thickness). potential issues with the way to the tubes are set up, or how they're soldered to the fins, or how they fins themselves are set up (straight instead of folded) resulting in noticeably weaker performance than other common radiators out at that time.
i did go ahead and order the 25mm-thick radiator w/ extra port last week that w360 previously mentioned, so i'll see how that compares to the "ST25" once it gets here.
copper. also received pic from shipping proxy earlier and can confirm that that taobao listing has fill port + doesn't look too bad-Is that rad Copper or Aluminium?
I think you have space for the SSD behind the front panel!I am thinking about adding a 2.5” drive behind the PSU mounted with double sided tape. Not sure how the heat from the psu will affect the drive the though. I’m not sure I can get a drive behind the front panel with the DC-LT 40 in the way.
Seems pretty nice!copper. also received pic from shipping proxy earlier and can confirm that that taobao listing has fill port + doesn't look too bad-
Here is what I cooked up this morning. After I was done, I realized my printer isn't big enough... This top panel has 3mm more height.
Edit: revised to add a lip that will be flush with front of case
you may want to cross check with ems.post too. For my tracking, it actually showed the update of when my case reached VN like 5-6 hours before 17track didAll you guys receiving the case are making me hella jealous. 2 and a half weeks since shipping and mine is still in China, having received the same message on 17track (The airline is shipping) 6 days apart (shipping to UK)
Got my case delivered today as well. Can't wait to get off work and start playing with it. Although I've seen many pictures from others, still very very impressed with the flat-packing ?
that is the only box that I received. If there was another box, VN customs must have thrown that out. They open every package coming into to VN and the reseal it with the EMS branded tape that you see in the pictureHmm.. didnt you get another box to open or just T1 box??
I received my T1 package today (in Sydney Australia) but it seems I must be missing a piece - one of the short brackets - super excited for the build though...
Hi @Wahaha360 my understanding was that we only got our tracking numbers once our package is on a plane right? I've seen several people on the reddit stuck on this step "Guangzhou City, leaving the Guangzhou International Center, the next stop "Guangzhou International Exchange Station" (via transfer)" and I assumed that the next update was going to be that the package arrived at the destination country, but I'm seeing people with an updated tracking that says "Airline is shipping". So are the packages stuck on the Guangzhou International Center actually on a plane or not? Not trying to be rude I'd just like to know what to expect.
I know delays are to be expected but I just want to know if yes or no my package is on a plane, if it is I can expect it here in 7-10 days (my tracking is stuck on Guangzhou International Center since the 28th) but if it's not then It could be coming in a month or more.
