Don't you use one of those motherboards, Fabio? Do you have this issue too, or is your case always open because of testing watercooling components?It’s a Gigabyte for sure, X570 or B550!
Yes I had that issue, but is not an issue actually. If you have a thin backplate on the gpu It just push a bit, but nothing crazy. I was using my GPU without backplate in that case.Don't you use one of those motherboards, Fabio? Do you have this issue too, or is your case always open because of testing watercooling components?
JRey, for documentation purposes, what motherboard are in those pictures?
Correct. It’s a Gigabyte B550i. I’ll update the previous post to include that information.It’s a Gigabyte for sure, X570 or B550!
This case is dope! Pretty sure with 3mm more in height, 2mm wide and 3mm in length can still be below 10L, and fits everything better!
(@Wahaha360 of course keeping the golden ratio!)
So 221x135x332 9,9L Instead of 9,8! ??
But ALL the SLIM radiator support!
You need stand-off of 21mm for the GPU (2slots or 3slots). And the front golden ratio is kept! ???
I am using the included riser.About the top/bottom panel, that’s no true it makes bulge it. You have to press a bit to close the panel, but there is no bulge.
I think, form the picture, @JRey is not using the included riser. Mine and the advertised one are different, and that is the reason why. (i've discovered it using the same that @JRey is using when I've received the case).
Here mine/included one
more pictures to give different views.
Oh, this means they've changed the riser! Sorry man!
On the buy page there is a part that says resources its in thereGot my case! Is there an official build guide?
Use the first optimumtech video
Yea the video is nice and helpful but the riser standoff part is rather confusing. I can't quite figure out the orientation.
what are you trying to figure out? I can try and help
Yep, it has to go below the top structure!Yea the video is nice and helpful but the riser standoff part is rather confusing. I can't quite figure out the orientation.
Edit: Here are some photos. Does this look right?
Also the riser cable doesn't seem long enough to wrap around the top. Is it supposed to go under?
Those pics are really nice, even the ones that you are asking for help on. If I was asking for help I would have just taken crappy photos with my phone and posted them here but no, you got out your camera and took high quality photos just to ask a question!Thanks all. I think I got it right. Since I can't fully build it yet till the rest of my components come in, it's just on display now.
Thanks mate I pulled out the macro lens for the first two pics cuz I couldn’t quite nail the focus on my iphone.Those pics are really nice, even the ones that you are asking for help on. If I was asking for help I would have just taken crappy photos with my phone and posted them here but no, you got out your camera and took high quality photos just to ask a question!
Looking forward to your build and the pictures you're (most likely) going to take of it!
