    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
worldtour
56
133
Don’t worry, you will get your package. I understand the excitement, but give it this week at least. Just a suggestion...
It's not about excitement. It's about planning. My apartment building requires me to submit tracking number for expected packages otherwise it gets routed to a warehouse and it's a huge hassle since I do not have a car.
PBJ
358
546
Well, sorry I was pretty excited when I was waiting for my T1, so I assumed you were.
For me, it took a few weeks to be delivered. I do not know the circumstances, but someone said on reddit that the tracking will update once it’s on board the freight plane. Don’t take this as a definitive answer since I just don’t know, but global shipping is complicated as you may know and I recommend waiting a few days.
Reactions: worldtour
notbitcoin
77
204
If your phone number was attached to the order, then DHL will text you when the package is processed into their system and then again when it is out for delivery (and both texts will contain your tracking #). I'd imagine if you haven't received that text, then DHL doesn't have your package yet, and so it's likely still with the shipping courier waiting for handoff to DHL.
nulio
50
38
I'd say it might be something on the code creating the emails. I also got an email with "Tracking number: AwaitingTracking!"
Either the email is being sent too early when there's not yet a tracking code or some mistake somewhere doesn't add the code?
IIRC W360 said he was trying to only send news when the product is shipped (=should already have a tracking code)
Is DHL handling the delivery everywhere or just in some countries?
Killdoc
40
29
Maybe Maybe, NO ALPHACOOL???
And Betwenn the GPU and the PSU you can see an Intel 905p connected to the back NVME SSD! ;)
@fabio
I have not seen any other build (might have missed it) where there is an added SSD in the case in this location. How did you get the Intel 950p to stick there? And are you using a NVME to SATA connector cable? I think with this current build you cannot place an SSD behind the front panel (too many cables and wires in the way). Am I wrong?
PKAWA
490
488
Honestly, it's all been said before! I am also waiting for a tracking number but the cases haven't been moved because they are waiting to be handled and shipped due to covid. When they are you will be notified, so please. Your life does not depend on it.
Reactions: DrHudacris
Polaris1981
For those that are water cooling, what temp sensor are you using and where in the loop is it mounted?
It would help to know your loop order as well.
Going with the AquaComputer Quadro (if I can fit it), although I might get a different temperature sensor like this:
For loop order, doing Rad-->CPU-->GPU-->DC-LT-->Rad, although I don't think the order matters TOO much. But i think this arrangement is going to be the easiest considering the layout.
fabio
1,885
4,325
Today was a long day!
THIS is the easiest and effective way to fill the system without a reservoir!
Someone asked this months ago, and in the end, here you go!!
The DDC 1T Plus PMW is incredible quiet!! I stay with this. I love my EKWB 3,1MX but is discontinued, so this is good to know for everyone who want to choose a DDC pump.
@Killdoc I've used just a velcro strap on the back of the PSU, you can see here in the image. In any case, this SSD is 15mm thick, so impossible to place behind the front panel!
And the Optane is connected to the back NVME port with this cable:
Bye, Bye Alphacool!!
@JRey I have the sensor just before the pump, to measure the hottest point (39C on my loop). Everything is run by the QUADRO.
grinny
30
36
I would like to learn about the shipment company too. Is it DHL to every country?
Since I live in Turkey, the best option for us would be Chinese Registered Mail, IMO.
DHL is milking people for money when importing goods :(
JRey
79
179
Awesome, thanks @fabio
How did you end up mounting the DDC? Is is just “floating” with the extension fitting? Or did you mount it to the panel somehow?
fabio
1,885
4,325
BTW, We have another 27mm radiator!
Navic
587
1,341
I never thought I would see an RGB radiator... but I guess it had to happen at some point.
On another note, I was researching all the stuff I would need for a custom loop and omfgosh it's so expensive. I'll probably have to do it when I upgrade lol
fabio
1,885
4,325
I know! But you have to think that the fittings are "forever", the tubing is cheap, and a good CPU block with a swappable mounting system is "forever" as well. The most expensive part and with less longevity is the GPU block! ?
posure
34
51
My T1 v1.1 case order has arrived, thanks @Wahaha360 !
Very excited to put it together. Initially I'll be setting it up with air cooling (3800X + Blackridge w/Noctuas)...but it was too hard to see all of these cool water cooling builds over the past few months, so I'll be transitioning to water cooling in the next few weeks.
Timeline for reference:
- Ordered July 3rd
- Shipped July 20th
- DHL tracking July 24th (estimated July 29th delivery)
- Delivered July 27th (Wisconsin, USA)
fabio
1,885
4,325
And here, the system ready!
I am using for both the fans the Noctua Low Noise Adapter and the pump range is between 25% and 45%.
With a 30 minutes Blender test the CPU stays at 69/70C and the coolant temp is 40C (32 in Idle).
In the ASUS board the Chipset reach 70C (With the Gigabyte was 65 MAX).
